Question about Zanussi zwh6160p
My zanussi zwh6160p will not spin after wash programme
When my washing machine is put on a wash programme it will not spin please help
  • 1462 Answers
SOURCE: zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Posted on Mar 21, 2007
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Posted on May 31, 2007
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
Ian Sy
  • 7 Answers
SOURCE: I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Posted on Nov 29, 2009
My zanussi zwh 6160p lets the water into wash but the drum won't move, I've checked the belt, motor and all seems ok, what could it be
if its around six years old it could be worn motor brushes not too expensive to buy or replace depending on yours skill levels.
Oct 02, 2016 | Zanussi ZWH6160P White 60 cm Washer Front...
Zanussi aquacycle 1200 want open
H? there
This somerimes happens t? my Candy, then I d? the same ?s you.
I also turn to off, wait the desired two minues> turn to empty, most often she does as she is told> turn off, wait the two minutes> turn to spin, turn off> wait the two minutes. This usually works and then I can put on any program. This works for me. Hope you find a solution for you,
kolbrun
Feb 04, 2015 | Zanussi Washing Machines
My washing machine sometimes fills with water in between washes so I have to drain it before putting a load on why is this
is it clean water or dirty water
if it is clean water you need to change the water valve
if it is dirty water then you need to lift the drain hose higher if it drains below the sink ( to stop the back fill from the sink)
Jan 29, 2014 | Zanussi zwh6160p
Zwh6160p set programme,start/pause light flashes, when pressed machine doesn't start, door does not lock either
Is the door shutting at all or is it just not clicking shut , there is a pressure switch / electronic switch on the door catch mounted on the machine main body which prevents machine running if the door is not shut correctly.
Nov 28, 2013 | Zanussi zwh6160p
Washing curtians
Select a delicate or wool programme, this will give you a cool wash and a slow spin.
Feb 03, 2010 | Zanussi F1045W Front Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Zanussi zwh6160p Logo
117 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
