Question about Home
Findin a replacement pump for ITT Marlow Gemini Plus R125P.-C
5 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: I have an ITT marlow bath spa pump which runs fine
If this motor is not turning then you will likely need a new motor. it has brushes inside the motor like a cordless screwdriver.
There are no parts for it. you will need to find another one.
http://www.uspartscenter.com/index.asp?PageAction=PRODSEARCH&txtSearch=nr2ac&btnSearch=GO&Page=1
Posted on May 08, 2009
uspartscente
  • 717 Answers
SOURCE: What is the wiring sequence for itt marlow sd 100
universal wiring on the Gemini pump since it works 50 Hz or 60 Hz
black=hot
white=common
green-ground
Posted on Aug 19, 2009
aquaman987
  • 927 Answers
SOURCE: Finding a replacemnt motor/pump for my Swirl-Way.
R150VS-19 - Gemini Plus
Call these people, see if they carry a replacement for the pump that you have.
Gary
Posted on Feb 21, 2011
uspartscente
  • 717 Answers
p, li { white-space: pre-wrap; }
This Pump & Control you have is no longer being made. It hasn't been made for over 5 years. You will need the following items: • new pump • air button • air tubing You will have to change the control on the tub to an air button. You will now only have on/off options instead of the multiple speed you currently have. The link below shows the replacement pump and just under that shows an Air Button you can use and get some air tubing as well.
http://www.uspartscenter.com/ittmarlowgeminiplusiinr4a-c15hp.aspx
Aqua Glass whirlpool with a Pentair pump wont turn on.
the pictures are not showing up. Sounds like maybe you have an ITT Marlow pump that has a circuit board on the back of it.
What model number pump do you have? I believe what you tell us here is model number R150VS11-C
If this is the case then what you have is a control with a knob on the top of it that controls the 6 speeds.
The control & "VS" series pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system includes the following items:
• New 1.5 hp Pump
• AirStreme Control box and topside control panel
You will change everything from the old system to what comes with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/airstreme_system.aspx
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 26, 2013 | Home
Finding a replacemnt motor/pump for my Swirl-Way. Failed pump is an ITT marlow, 11.5 amp. Mo: R150VS-8-C, Spec: 0094C00C Any help would be appreciated
Feb 21, 2011 | Home
I need help findin the fuel pump relay in a 1995
the fuel pump relay is under the hood on the drives side if u look in the oners manual it will show u the excact location hope it helps
Feb 10, 2010 | 1995 Mitsubishi Eclipse
Pump leaks
Found the parts needed on eBay.
Jan 20, 2010 | Hydro Systems ERI6060ACO Designer Series...
I have a Jabsco Sonic pump switch for my bildge pump. I lost my instruction manual and would like to replace itsi I can install it. Thank You, Ken
I am fairly familiar with Jabsco switches but I don't recall a sonic switch. Do you have a digital photo?
Nov 24, 2009 | ITT Jabsco Boating
What is the wiring sequence for itt marlow sd 100 bath pump in uk (colour code of wiring?)
black=hot
white=common
green-ground
Jul 10, 2009 | Home
I have an ITT marlow bath spa pump which runs fine until the pump is attached when it wont start. It just sits and hums until I give the impeller a spin. Any ideas?
Apr 26, 2009 | Home
Home Logo
63 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
