Question about Onkyo TX-SR600 Receiver
Onkyo txsr600 amplifier protection circuitry activated... how can it be deactivated?
5 Suggested Answers
  • 15 Answers
SOURCE: onkyo HT-R500 amplifier protection circuitry activated
u have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
Posted on Jan 12, 2009
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: Onkyo TX 8211 protection mode is activated and i
Eliminate the short or overheating problem it thinks exists. Disconnect all speakers first to see if one of them is the culprit. If it's internal, take it to a shop.
Posted on Jan 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an Onkyo TX-SR500.
No one would be able to troubleshoot it over the phone or internet. Take it to a reputable shop and get an estimate, then decide if it's worth the cost.
Posted on May 18, 2011
I have an Onkyo TX-SR500. I turn it on, and immediately it shuts off. Under troubleshooting it says, "activated amplifier protection circuitry". Here is my issue: I've called Onkyo USA...
May 17, 2011 | Onkyo TX-SR500 Receiver
This site said it was free - then there is a charge? I am getting a "Protecting" message when I turn on my receiver - then it shuts off....What does this mean and what should I do?
It means the receiver senses excessive heat, or a short at its outputs. Disconnect the speaker wires and see if that helps. If not, get it to a Tech. If it turns on, figure out which speaker path(s) was causing the problem and resolve it.
The manual.
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Power shuts off immediately after power on.
• Amplifier protection circuitry is activated. Remove the power cord from the outlet immediately. Contact your Onkyo service center.
Jan 13, 2011 | Onkyo TX-SR601 Receiver
Onkyo TX 8211 protection mode is activated and i want to know how to deactivate it????
Jan 19, 2010 | Onkyo TX-8211 Receiver
I think the amplifier protection circuitry has been enabled. do you know how to reset it?
Check the audio amplifier IC maybe are damaged and need to be replaced
Jan 18, 2010 | Onkyo TX-SR600 Receiver
Amp protection circuit has been activated
sometimes the protection circuit will enable because of a bad speaker i would suggest taking the load off of it by removing the speaker wires and turning it back on. if it stays on take an ohm meter and check the speakers should be between 2-4 ohms load.
May 01, 2009 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Apr 21, 2009 | Onkyo HTR500 Receiver
Onkyo HT-R500 amplifier protection circuitry activated
u have a short.
1: turn it off.
Good luck
Oct 27, 2008 | Onkyo HTR500 Receiver
No power
My receiver has a similar problem. So far I have found a pair of output transistors fried shorted E to B to C (Q6051 and Q6061) and the associated ceramic current limiting resistor array (R6101) failed open. These bad components will definitely be sensed by the protection circuitry as an overload condition. I ordered some replacement transistors from Mouser (2STC4467 and 2STA1694) and the resistor (RSS2WK-0.22 ) from Encompass.
https://www.encompassparts.com/
I will let you know if this corrects the problem once the parts are installed. I also got a service manual from www.user-manuals.com which helps a lot.
May 27, 2008 | Onkyo TX-SR500 Receiver
TX-SR800 circuitry protection activated
You maybe got to change the ICs audio amplifiers of the receiver they are damaged.
Apr 06, 2008 | Onkyo TX-8511 Receiver
Power shuts off immediatly after power on
you may have to many electronics plugged up to one circuit in your house. try plugging the sound system into a different socket and that might help.
Oct 31, 2007 | Onkyo SKS-HT500 System
Onkyo TX-SR600 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
