Question about Garden
Is there an air filter on poulan pro pr621 snow thrower ?
Ive changed the spark plug and added fuel saver. someone told me to spray air filter with starter fluid. is there an air filter?
  • Dennis Goethe
    Dennis Goethe Feb 11, 2018
    Mine is also missing an air filter. Is there supposed to be one? Seems like the "experts" could give a simple "yes" or "no" answer?
  • Garden Master
  • 13,076 Answers
99% of snowblowers do not have a air filter
Posted on Feb 11, 2018
  • 398 Answers
SOURCE: 2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
Posted on Feb 26, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Posted on Jun 08, 2009
carlsbiz
  • 1124 Answers
SOURCE: Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Posted on Jul 09, 2009
  • 715 Answers
SOURCE: !332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Posted on Oct 07, 2009
SOURCE: Just purchased a Poulan Pro Snow Thrower and on
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Posted on Nov 30, 2010
Snow thrower doesn't start up!
If you have a spark at the plug (you have checked?) it's probably fuel blockage. Check all lines, fuel filter and carburettor are clean, use a carburettor cleaner spray to get all the gum out.
Feb 23, 2014 | Garden
Tip
Snow throwers
Just returned from the parts store, they had sold out of drive belts for the auger drive on snow throwers... figured I could help out here;
Wet snow is heavy, duh right? Before you run your snow thrower disconnect the spark plug, for safety. Check the chute, and sand any loose paint rust etc. you want a smooth chute.. paint if needed, let dry 24 hours before use, spray with silicon lube spray, this will loessen the stress on your auger belt and hopefully keep your machine running all season. Good luck!
on Feb 28, 2010 | Air Purifiers
Starting poulan pro snowblower
gas spark and air , if you have these 3 it will start , which one do you not have
Jan 12, 2014 | Poulan Pro Pr621 21-Inch 208cc LCT Gas...
Snow thrower not starting
Two ways to find out:
1.
2.elctric
start with elctric, take the plug cable out and see if have
https://www.youtube.com/watch?v=mUOmsGiirTU
if you have spark go to fuel :
change the old fuel to a fresh one.
https://www.youtube.com/watch?v=RfzzTilqwo0
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Snow blower won't start
just take off the AIR filter and thar is a Big Hole thar spray sum starte fluid in the bigger hole and spray it for three sec then try an start it
Dec 17, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Oct 07, 2009 | Garden
Just purchased a Poulan Pro Snow Thrower and on first start after assembly [new gas and 10W30 oil] the engine RPM has a rythemic surges about once a second. When a little choke is applied, the RPM becomes...
Oct 01, 2009 | Garden
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
