Question about HP DeskJet 6450 Printer
HP6450 says fax log is full and cannot recieve or send.
The screen on the printer says fax log is full and cannot send or receive faxes, but no way to delete or empty fax lot.
    Genius:
  • 2,035 Answers
  1. Press the Setup button (HP6450 says fax log is full and cannot recieve or  - c01361401.giftools ).
  2. Press the Right arrow button (c01185072.jpg> ) until Tools displays on the control panel, and then press OK .
  3. HP6450 says fax log is full and cannot recieve or - c01185072.jpgress the Right arrow button (c01185072.jpg >) until Fax Log displays on the control panel, and then press OK . HP6450 says fax log is full and cannot recieve or - c01185072.jpg
  4. Press the Right arrow button (c01185072.jpg> ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clearHP6450 says fax log is full and cannot recieve or - c01235250.gifthe control panel.
  5. Press the Cancel button (c01235250.gif ) to exit.
Posted on Jan 20, 2009
I can send fax but not recieve fax
Check your Ink cartridge if it is fully empty means it will not print received faxes so it will save in memory
Feb 04, 2013 | HP Officejet 4215v All-in-One Printer
Hp c6180 fax not working. Message: Unable to send or receive faxes, press Os to continue Despite the all possible settings and driver updates, the fax has never worked. How can I fix this?
Follow the steps one by one
1. Press the Setup button - Press OK
2. Scroll to Tools - Press OK
3. Press OK on Run Fax Test
4. It will list you possible causes why you are not able to send/receive fax
If you cannot solve the issue with the Fax Report, you can do a semi-full reset on printer
( do not do the semifull reset on printer if connected to wireless, If you do so, the printer will loose wireless connectivity to router and you will have to setup the printer on router again )
Disconnect the power cord from back of printer ( when printer is powered on )
Hold the # and 6 button and while holding connect the cord back
This reset will Erase fax logs, wireless connectivity any other memory stored in printer
Follow the instructions on printer screen to re-align the printer and cartridges
Try to send/receive fax and it should work.
* Please rate this solution with Thumbs up and comment to help us improvise in providing better support
Sep 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
C7180 can't send or receive fax? this worked a
press setup button. scroll to advanced fax setup. press ok. scroll to ecm press ok. select off. then press ok. then press cancell button to go back to main screen. now try to send and recieve fax.
Dec 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
I live in Saskatchewan Canada and can send Faxes to British Columbia, but I cannot recieve from there.
Make sure whoever sends you the fax is using the full fax number - if that isn't the case, I would call your phone company to make sure your fax line is capable of receiving long distance calls.
May 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Pixma 830 - have two, one upstairs and one downstairs. Use the lower one for full faxing. Can I set up the upper one to send faxes only and not recieve faxes? I assume you couldn't set up both to send...
no.this is not possible from 1 line.but if you use two lines it is possible.
1 for receiving and 1 for sending.such option is there in the printer.
Nov 14, 2008 | Office Equipment & Supplies
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
HP DeskJet 6450 Printer Logo
541 people viewed this question
Ben Johnson
