Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Old coleman dome heater wont light
Have old heater turned upside down and added white gass to dome wont light in fact splatters fuel what am i doing wrong
    Novelist:
  • 88 Answers
Sounds like your feed tube might be partially plugged, or the orifice, you will need to disassemble the unit and clean it, normally a good dose of high pressure air will clear the tubing and orifice, check the tank too to see if you have any de-bree in it, hope that helps.
Posted on Jan 20, 2009
I have the Coleman Presidential Heater in a 1976 travel trailer and the pilot light/gas unit has broken off and I need to know where can I find an NEW ENTIRE HEATER to replace it? Thank you
They are pretty standard... get the old one OUT...
Take it to the hardware store and have the STAFF there help you do a STARE & COMPARE).
Be careful not to overtighten the coupler when re-installing
1973 COLEMAN 512A700 3500 BTU CATALYTIC HEATER BOX PAPERWORK EUC
Sep 14, 2016 | Coleman Heating & Cooling
What fuel does my 335 lantern run on pat no 1969 globe 4,mantle 999 generator 63 0n bottom fuel tank has a no 937416 and year 1969 any information would be great
happytimes17-
This lantern is designed to run on gasoline, but will work best with white gas, also generically known as "coleman fuel" in many areas. White gas is in fact a more pure form of gasoline, without many of the fine particulates and impure distillates found in automotive gasoline.
Most hardware stores and sporting goods stores carry Coleman or other brands of white gas.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Sport & Outdoor - Others
Bought kerosene heater in middle of November and seem to have a wick issue. It will not burn properly and makes me wonder if wick was place in upside down. Can I fix it myself?
Trust me you can not install a wick upside down, the bottom of a wick is like an old mop. It has loose wove string and knots, it's job is to **** up fuel. Things to remember about wicks are, they need cleaned some times, I use an old tooth brush and gently brush the wick with it set down low so it does not get damaged. A wick must also sit and soak for at least a half hour before attempting to light it. A good practice to get in to is about every fourth tank of fuel let the heater burn out, this also cleans out the wick and burns off all of the impurities from dirty fuel. Yes you can check your wick but the entire heater does have to be tore down and you should do it only with an empty tank of fuel. This takes time , patience, and a little mechanical know how. When burning out a heater please remove it from your house and let it burn the smell is terrible, if you do this in your house it will smell like a semi truck is running in it.
Dec 28, 2010 | Heating & Cooling
Coleman powermate maxa 5000 er - been sitting for about 2 years and I want to start it up again. Checked oil, ok. added new gas (but did not drain old). Fuel valve open, spark plug cap on. Engine won't...
it could have sezed up on you take out the plug and try to turn the motor by hand if it wont turn its sezed up,,,if so all you can do is tip down the plug hole a small brop of red x or two stroke oil and rock the motor back and frow till it frees off,,
if it frees off that is!
Aug 30, 2010 | Electrical Supplies
Wont start
when you added fuel to the old fuel in the tank, i advice you to take all the fuel out, clean the carb, blow out fuelrestrictors in it and fill up with new fuel and try again. also check the sparkplug, and check if it sparks. good luck.
Feb 13, 2010 | Coleman Powermate Powermate 5000W...
When I light my Coleman Catalytic Heater, it burns
The wick isnt drawing up any fuel? Does this heater have a primer?
Could the wick be sitting above the fuel inside the tank?
You might just try changing wicks and restarting.
Dec 12, 2009 | Coleman Heating & Cooling
Rough age 1960s coleman catalitic heater. round green with a domed top.
the coleman uses a vermiculite "sponge" in the dome. after you pump it up and start it, there should be a quarter to half dollar area on the dome that gets saturated with fuel. you light this area then open the valve all the way. the entire dome should glow orange.
May 17, 2008 | Coleman 5031-750 Utility Heater
Heating & Cooling Logo
198 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
