Question about Sony DHC-FL7D System
My Sony DHC-FL7D cannot eject the disc
Its very clear that my problem is that I cannot eject the disc tray. Every time i try to eject it, the display will show "PLEASE WAIT", and I wait for 1 whole week, I just let it be at that state, if by chance the disc tray will come out but to no avail. I would like to know if I can fix it myself or if not, I want to know how to force the disc tray to come out. Thank you in advance
  • hariti Jan 07, 2008
    sony dhc-fl7d does not eject the disc
  • suressss Apr 29, 2008
    Same problem
2 Suggested Answers
SOURCE:
SOURCE: i can not eject the disc tray
I too had a similar problem with my DHC FL7D. The front moving panel would not move up. The screen used to say 'please wait' endlessly whenever I pressed the DVD button. I thought the drive belt might have got cut. There is a drive belt for the front panel to move upwards and downwards. Since that was intact, I disconnected the front panel from the main body to access the DVD drive system. I had to disconnect many cables and PCBs to do so. Then I opened the DVD compartment and removed all the DVDs which were stuck and re-alligned all the disc trays to its original state. I checked if all the drive belts inside the DVD compartment, it was ok. Also I tried moving the laser lens assembly to check if it was moving. Since there was no problem I closed the system. <br />After I switched on it worked again . I think it might be to do with the fact that the disc trays might have been stuck for some reason or may be the there was a software glitch.<br />
Posted on Aug 20, 2010
How to unlock sony dvp- sr320
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Aug 10, 2015 | Sony Televison & Video
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
I have a panasonic dmr ex77 and it has suddenly stopped working. when you turn it on the dvd tray ejects and the display shows HDDERROR
Good day!!!!
that problem is cause of malfunction/defective HDD or hard disk inside...
please try to open the cover and remove connectors on hard disk then power it ON..wait for showing of display...
after that power it OFF again and after 1 minute reconnect the connectors of hard disk..then try to power it ON again..
if the problem persist...the hard disk is corrupted you need to replaced it..
Jul 24, 2011 | Televison & Video
I have sony HCD-FL5D and I can't get my disk out of it,when turn on my device it displays "PLEASE WAIT" I have waited but nothing special happend,what should I do?
i have a sony HCD-FL5D .it is not playing disc and not eject disc and when playing tape A/B it is on standby. i am worried about this please helpe me.
Apr 01, 2011 | Sony DHC-FL7D System
What should i do with that "push protect power"??
Get the manual...
http://www.retrevo.com/s/Sony-DHC-FL7D-Home-Theater-Systems-review-manual/id/268ag224/t/1-2/
Page 60: Lower left corner.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 08, 2011 | Sony DHC-FL7D System
I have SONY system HCD-FL5D, I get msg "power protect" and system hangs, what might be the problem? How can solve this problem? Please help..... Thank you very much
Page 60
http://www.retrevo.com/support/Sony-DHC-FL7D-Home-Theater-Systems-manual/id/268ag224/t/2/
It senses an external short. Disconnect the speakers and try again. If it comes on you have a short out toward one of the speakers. If it still won't come on it needs to see a doctor.
Jan 11, 2011 | Sony DHC-FL7D System
Sony DHC-FL7D System Logo
98 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
