Question about Exercise & Fitness
Pro form cross trainer 55 emcumbent bike digital controls not working
Programs will not work
SOURCE: lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Posted on Mar 20, 2009
SOURCE: instruction manual for olympus cross trainer
I cannot get the timer to work on the olympus sport ascent cross trainer.
Posted on Aug 19, 2009
  • 3 Answers
SOURCE: Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Posted on Jun 19, 2010
  • 218 Answers
SOURCE: my control board does not work...buttons cant be
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Posted on Aug 13, 2010
ercupa190
  • 12223 Answers
SOURCE: belt off of pro form 700 cardio cross trainer
Dear Sir: Hello , I hope everything is fine.
Please do the following: o 1 Remove the key from the machine and unplug the unit for safety purposes. o 2 Adjust the rear roller adjustment bolts using an allen wrench. The right bolt should be turned one-fourth turn clockwise and the left bolt should be turned one-fourth turn counterclockwise. o 3 Place the key back into the unit and plug it back into its power source. o 4 Run the Proform treadmill for five minutes to make sure that the walking belt has fully recentered itself. o 5 Repeat these steps if necessary.
If the Belt Slip when in use: o 1 Unplug the unit and remove the key card. o 2 Tighten the walking belt by turning both rear adjustment bolts clockwise using an Allen wrench. o 3 Replug the unit and reinsert the key card.
Thank you in advance, sincerely. Blessing.
E.CUADRA Managua, Nicaragua. c.a.
Posted on Sep 26, 2011
Pro-form 650 cross trainer - when started the belt goes fast for 3 seconds and stops.
The Motor controller board is faulty. That's why its runs on the Top speed and and shut sown due to the over current consumption
You have to replace the motor driver or get it repaired.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 10, 2017 | Exercise & Fitness
The bike is locked. It's not working
could be the drive belt could be jammed either torn or other.
Aug 21, 2014 | Life Fitness X3 Elliptical Cross-Trainer...
I need a left peedle for my confidence fitness 2 in 1 cross trainer bike please..
dont know if you got one but I needed a right pedal and it cost me 10gbp from the manufacturer all I had to do is ring them on 01527 598388 and it arrived within 24hrs I was very surprised. item number 23-pedal http://g-ec2.images-amazon.com/images/G/02/uk-sports/Team/B000QZ54MS._V358643820_pdf
Aug 01, 2013 | Confidence 2 In 1 Elliptical Cross Trainer...
What is an elliptical trainer?
An elliptical trainer is a stationary machine used to stimulate the action of running, stair climbing, or walking. It puts barely any pressure on your joints giving you a great non-impact cardio workout that can vary in intensity levels.
Aug 02, 2012 | Exercise & Fitness
Hi I have a Reebok i series 1.1 cross trainer that my friend kindly gave to me. It was in perfect working order till I took it apart for transport and put it back together...now the tension control no
adjust the magnet the tension depend from this device, tight the bolts with some wrench. Test the magnet with the magnet refrigerator, for to see if attracted or repeled, change it if necessary.
sincerely.God bless you
Apr 18, 2012 | Reebok Crosstrainer i-trainer s
Dec 31, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Instruction manual for olympus cross trainer
Jun 28, 2009 | Exercise & Fitness
Lost instructions for Rober Black cross trainer
Feb 01, 2009 | Exercise & Fitness
Exercise & Fitness Logo
24 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
