Question about Foxconn Computers & Internet
My mather bord n15235 give no display but cpu fan is rotating i also cake ram & cpu on another bord thay are ok and monitor also ok
    Problem Solver:
  • 15 Answers
Compatibility problem.
Posted on May 26, 2014
  • 54 Answers
SOURCE: monitor
Reset the Cmos battery,check the RAM,check the smps or check the motherboard ground, I think you problem will solve.
Posted on Feb 16, 2008
cropp
  • 377 Answers
SOURCE: No beep,No Display on my monitor,only CPU heatsink fan is moving
dear reclane
theat sound is sign of memory needed to your motherboard, try using a brush to clean your memory, after that you can put your memory again
or you can try to clear cmos with short the jumper the right next battery cmos, short pin 2,3 and power on yor pc. after that put in normal position
the last try to change your power supply with a new
oke
i hope it can solved your problem
thx
cropp
Posted on Mar 17, 2008
SOURCE: No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Posted on Jul 05, 2008
SOURCE: mother bord not a display
mother board
not display show
Posted on Dec 01, 2009
chiplevel
  • 656 Answers
SOURCE: no display but power on ram ok cmos battery ok cpu
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Posted on Oct 07, 2010
No display cpu fan and led indicators are working fine.Iam using RoHS Compliant N15235 motherboard.Can u tell me what will be the fault?
I don't know much about these things but I understand if everything is ok there is an audible beep shortly after switching on, at least all of my pc's have beeped. According to my motherboard manual there is all sorts of beeps as an aid to fault diagnosis.
As there is no display perhaps there is something wrong with the graphics card. It looks as though your motherboard has on-board graphics and it might be best to use those initially with a known good monitor.
Jun 25, 2016 | Computers & Internet
Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
Jan 19, 2011 | HP Pavilion A1710N Desktop PC
No ram beep is ok but there is no display
pls. replace with a new same rating RAM
Apr 06, 2010 | Intel Motherboard
No display on monithor cpu fun runs &but mobo led
do it only if u r a professional..
assuming that the system bios hs not been flashed or updated in a wrong way..if so u gotta replace the m/b..
1st see if the ram(s) is loose/faulty..open n resit it..
check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
if all above are ok..check the cmos/system battery..(above +3v)..
check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby..
there may b also problem with ur monitor or display adapter, try replacing with a standby..
hope it'll b enough to solve ur problem..
seek professional assistance of ur system admin/vendor....
Nov 03, 2009 | Intel D845GVSR Motherboard
No any display & sound then i power on my PC my pc is intel 815t abit st6, red led is always on but no display? can any one help me??????
First check your num lock key led if it on and off when you press num lock then your cpu gives diaply to monitor perfact.
Then check your display connection from monitor to cpu.
When you power up the computer pressF8 ket then enter in enable vga mode.Then go to control panel -> display->property ->settings.
Then change screen resolution to 1024*768 then apply and ok .
But if you still not get dispaly then
-> Open cpu cabinet.
-> Refix RAM meory clean all dust from motherbord chip set .
-> pull cmos cell for 15 minutes.
-> Reattch ATX power supply to motherbord.
-> Refix processor it is bottom of processor fan.
Please rate my solution if it help you .
Thanks for using fixya.
Jul 20, 2009 | Computers & Internet
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Jan 31, 2009 | Compaq Refurbished 280WATT POWER SUPPLY...
Mother bord not a display
mother board
not display show
Oct 19, 2008 | MSI K8MM-V Motherboard
check different working ram, also take out the cpu fan then place it again, then check
Oct 19, 2008 | Intel D845GVSR Motherboard
Monitor
Feb 16, 2008 | Computers & Internet
Computers & Internet Logo
78 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
