Question about Hotpoint RFA51 Bottom Freezer Refrigerator
TEMP LIGHT ON
FRIGE FREEZER FRA51P OVER TEMP LIGHT ON COMPRESSOR NOT RUNNING !!!!! ANY IDEAS ?????
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
I have a amanda 1bb1924dew bottom freezer frige. The compressor is running and cools the freeezer to normal temps but the frige area is about 60 degrees. I set the frige control on high and it still does...
12002355 Thermistor
Are you sure that the model is not ABB1924DEW? I want you to test the=> 67003903 Damper Control Assembly Here is a ABB1924DEW Service Manual and you will need to place refrigerator into self diagnostics. The problem is either a defective 12002355 Thermistor or a defective 67003903 Damper Control Assembly Here is another source for the 67003903 Damper Control. Here is a ABB1924DEW Parts List and a ABB1924DEW User Manual You are going to have questions so please ask, Thanks Sea Breeze
Feb 01, 2013 | Refrigerators
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Jul 14, 2009 | Jenn-Air JFC2089HE French Door...
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer side is fine but frige side is hot
the fridge side light bulb may be staying on,check door light switch
May 02, 2009 | Maytag MSD2656G Side by Side Refrigerator
The freezeer works just fine, but the frige is only about 68 degrees. it is about 100 degrees outside here does affect operation.Frige and freezer have seperate temp adjust.
What is the temperature in the freezer? Anything below 32 degrees freezes water. Make sure condenser coil is clean and that air can flow over it freely. In the back behind a removable panel you will find the condenser. Clean it completely and make sure the fan operates when the compressor is running.. Also check for possible frost on the back wall of the freezer which would indicate a defrost problem. if there is frost there the problem is ether a bad timer, heater, or defrost thermostat.
Jun 11, 2008 | Frigidaire Refrigerators
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Hotpoint RFA51 Bottom Freezer Refrigerator Logo
37 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
