Question about Refrigerators
Hi, I have an LG refrigerator that has stopped cooling altogether.
Trying to figure out what's wrong, I removed the back panel and listened to it running. The fan runs but what I noticed is there is a click noise and then the compressor seems to want to start running for about 5 seconds as I can hear it buzz and then another click noise and it stops. This happens like every two minutes. I try to make out if the click sound is coming from the compressor or from the overload/relay unit but I can't tell for sure. I already ordered a new overload and relay but I'm not too sure anymore. Really hoping it's not the compressor and that'll end up costing me a new fridge. Thanks Mark
  • Mark Grekoff Jan 07, 2013
    There's an electrical spark when the click stops the compressor
    President:
  • Refrigerators Master
  • 1,922 Answers
Its the ptc overload/relay,but make sure to check the compressors motor winding resistance on both start and run windings theres 3 terminal pins where the ptc overload attaches the single pin above or below the other 2 pin terminals is the common terminal,check for 8-11 ohms between the common and each of the other 2 terminals,then if no resistance or zero resistance then its the compressor,also check from the compressor case to each terminal at a time to make sure compressor isn't grounded to the case
Posted on Jan 07, 2013
  • 1 more comment
    Thanks for your answer Daniel. I don't have an amp meter so I'm not able to check the resistance. I really hope it's only the overload/relay. Already ordered the parts.
  • daniel  hendrickson
    daniel hendrickson Jan 07, 2013
    Mark,you only need an ohm meter to do the resistance test,even a cheap radio-shack ohm-meter will work in this case
  • Mark Grekoff Jan 10, 2013
    Problem fixed. It was the overload/relay indeed.
  • 833 Answers
SOURCE: Refrigerator buzzes & clicks
The only thing a capacitor does is 'kick' the compressor to start it. There is a box on the compressor containing the start relay. If it is defective or dirty, it might buzz. With the power off, find it, remove its cover and use some canned air to blow off any dirt inside. If that doesn't fix it, replace it. If there is a fan down there, be careful...and be sure it is working.
Posted on Dec 23, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
philbran
  • 242 Answers
SOURCE: Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Posted on Jan 07, 2009
  • 45 Answers
SOURCE: Whirlpool refrigerator model ED25PQ. Interior warm
possibly the relay on compressor is bad. the relay will need to be removed. shake it, if it rattles and or particles fall out of it, it is bad.
Posted on Jan 08, 2010
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
Frost develop and stop cool and freeze.
heatman101
Jul 02, 2011 | Refrigerators
The freezer keeps things frozen, but not 100% & the fridge is not cooling at all
heatman101
May 24, 2011 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator stoped cooling so i removed the back panel & noticed the compessor trying to cycle, but would make a clicking noise and kick out...how can i test to see if its the reley or compressor?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 04, 2011 | Amana ASD2626HE Side by Side Refrigerator
Hello I have a LG GRF 459BSCA Fridge Freezer. The fridge has stopped cooling, We were told to turn it off for a while, then back on again. Now the Fridge freezes!. Could you help with this please and...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | LG Refrigerators
Frozen solid freezer, warm refrigerator. (model Amana bottom freezer abb1922few) Can see frost on freezer foods and back vents (almost occluded). Just vacuumed wads of dog hair/dust off of front half of...
heatman101
Aug 27, 2010 | Refrigerators
Refrigerator section not cooling
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
