Need codes for universal remote control ona12av058
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
SOURCE: Need universal remote control codes
Well I have a nexx tech universal remote control model 1519001B but I lost the code list and I nedd the code for a JVC tv.
Posted on Nov 11, 2008
SOURCE: codes for universal remote control
Go to this website:
http://safemanuals.com/
Insert the brand "WELLTECH" and manualy the model "htfb 85" or "40085".
Download the user manual in French. This file have all the codes from page 23 up tp 37.
Best regards.
Posted on Feb 24, 2009
SOURCE: universal remote control code
I have a Dynex t.v, but my remot control doesn't work .
Posted on Apr 25, 2009
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
Posted on Apr 09, 2010
I have a duraband ht395 reciever and need the universal onn remote model ona12av058 code.. All the ones in the manual do not work? Anyone know this?
[PDF]Instructions - ONN Universal Remote Support
myonnremote.com/.../ONB13AV004%20Manual%20Version01.pdf
Mar 28, 2014 - will retain the codes you have programmed for up .... TV/DVD Combo, you might need to set up one ... Point the remote at the audio receiver,.
Faq - ONN Universal Remote Support
myonnremote.com/onn-faq.asp
How do I manually enter codes for my ONN Universal Remote? ... (You haveapproximately two seconds after the device shuts off or begins playing to lock-in the code.) ... so if you need to start the search again, it will pick up where it last left off.Missing: duraband ‎ht395 ‎reciever
RC: Durabrand codes one for all (Page 1 of 2) - Remote Central
https://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?...
May 4, 2006 - 15 posts - ‎9 authors
Jan 25, 2016 | Televison & Video
What is the code/codes to a onn universal remote control model number ona12av058 to a hitachi television
0219,0227,0261. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jun 14, 2015 | Universal Remote Control Televison & Video
What are the codes for an Emerson TV?
It should list it under Emerson. If coded won't work, you should follow procedure to get unknown code,.
Don't have the manuasl?
http://myonnremote.com/downloads/onn-ona12av058-and-39900-manual.pdf
May 23, 2015 | Onn ONA12AV058 Universal Remote Control -...
I need the codes for my remote
The codes are stored in the remote. What you really want to know is the code for some particular device.
Oct 29, 2014 | Onn ONA12AV058 Universal Remote Control -...
Can you gvie me a Onn code for SV2000 Video Cassette Recorder
0020,0025,0028.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 09, 2014 | Onn ONA12AV058 Universal Remote Control -...
Onn remote code for samsung tv
2607,2665.
Aug 25, 2014 | Onn ONA12AV058 Universal Remote Control -...
How get universal remote model ONA12AV058 to work info button for emerson tv model ltdn42v68us
Universal remotes have loads of codes in the remote.to select the right one first select tv button then select the on button over and over again until the tv turns on. Thesis then the right code. Sometime it take 200 pushes of the power button to find the right make and model of the tv.
Nov 04, 2013 | Televison & Video
Televison & Video Logo
3,261 people viewed this question
Top Televison & Video Experts
