Question about BafoTech BAFO USB 2.0 Storage Cabinet
Adapter I lost the adapter to this unit. The enclosure doesn't indicate the necessary voltage/wattage so I can replace the adapter. Does anyone know what the adapter specs are so I can buy a replacement? Or how to reach BAFO Tech?
  • 432 Answers
AC adapter (100-240VAC, 50/60Hz, 2A, 12VDC output)
Posted on Jun 30, 2007
SOURCE:
I lost my power adapter for my simple tech 1tb 96300-41001-172, what is the voltage, amp rating as well as what pole is the +?thanks.
Open it up and look inside. Some enclosures use screws others use plastic clips which may require a tool thinner than a credit card to release the clips.
The Internal Drive...Is it a 2.5" drive that runs on 5 volt or a 3.5" drive that uses combined 12 volt & 5 Volt power supply.
These drives don't use much current. 1 to 2 Amp
The adapter may have had a single voltage output for 2.5" drives or a dual voltage supply for the 3.5" Probably 12v or 5v
Anyhow, there are lots of hard drive empty enclosures that can be bought... as hard drives internally use a standard connection for data & power. Just swap the internal HD over to a new enclosure.
Hope this Helps
Trevor
Aug 07, 2014 | SimpleTech Computers & Internet
Power output
I don't know what you're asking about but if you need a power adapter you can find them cheaply online by searching google or yahoo etc. for the particular brand you need. There are tons of dealers out there with quality reconfigured, rebuilt and even new adaptors for very low prices. Good luck!
May 29, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Lost my adapter (65w), bought a universal laptop adapter but it is rated at 90w. will this work for my everex stepnote nc1502?
Correct voltage Greg?
Then yes it will work
More Wattage means more Amperage.
Same voltage, but more Amperage
(Voltage times Amperage = Wattage )
KEEP the inside of your laptop CLEAN
Make sure you occasionally replace the Thermal Paste on the Processor (CPU), and Thermal Pad on the graphics chipset. (GPU)
Service Manual for disassembling the laptop?
Everex is out of business (To my knowledge), and I see no service manual available.
I should be able to step by step you through it, anyway; if you desire
Regards,
joecoolvette
Apr 17, 2013 | Everex StepNote NC1502 Notebook
Hiya, does anyone know where i can get a charger for a R M z91fr laptop ??
If you can identify what the battery / laptop power requirements are, then you can buy replacement 'universal' laptop power supply / charger units which come with a selection of different standard connectors to plug the charger into the laptop.
Amazon sell a Sumvision Universal Laptop AC Charger Adapter which is available in different power output wattages (95V 120W). - you just need to select the correct DC output voltage by a switch selector and the correct connector for your laptop.
Jan 01, 2012 | Computers & Internet
Running a lacie hard drive with mac mini - after 2 years will not show up on desktop or in utility disk window
There are several possible reasons for this.
The most common is a short or failure in the Lacie enclosure caused by mixing up power/AC adapters. If your two Lacie drives are different models and you accidentally used the wrong adapter you may have damaged the circuitry.
The second possiblilty is that your power adapter or USB/Firewire cables could be damaged. Try switching USB/Firewire Cables First. If this fails to work then check if you have a smae sized adapter with the exact same Output Voltage and Amps on both adapters. Only if they are identical try switching adpaters from the working unit. If they are not proceed to the below solution.
Finally if the unit was dropped, bumped or unplugged while it was running it is quite possible that you may have damaged either the drive or the file structure on it, either of which would cause it to stop showing up.
Solution:
Try the cable swaps if able, if they work, replace the USB cable or replace the entire enclosure if the power adapter is the issue.
If neither works then you have either a failed hard drive or failed enclosure. Go to your local PC store (not a big box and yes PC, they tend to have more experience and parts to work with in this type of situation), have the techs there remove the drive from the Lacie enclosure and place it in a new enclosure for testing. They may not be able to see your files but they will be able to tell if the drive is working. If it is, buy the enclosure, then connect the drive back to your Mac. If it works you're done.
If the drive works but the Mac still doesn't recognize it(doesn't show up on the screen), then comment back and I will get you the link to a program you can use to retrieve the lost files.
If the drive simply fails to show up at the store in the new enclosure you will need the help of a pro to recover any important files. If that is the case reply with your location, Country, State and City and I will recomend an appropriate facility for you.
Hope this helps FixYa,
Chris
Jan 30, 2010 | LaCie Computers & Internet
Green light on ac charger goes out when i plug it in to lap top
This indicates a short in the computer or power supply. The power supply senses the problem and shuts itself off. Does the laptop run at all? More info. is needed to correctly solve your problem. Send me a message and I will help you out. Phil
Dec 09, 2009 | Dell Inspiron 1501 Notebook
I applied the wrong ac adaptor to my external hardrive
My laptop adapter delivers 4A (ampères). Examine the HD adapter, and read all markings, looking for output intensity ( a number followed by a capital A). Do the same with you computer's adapter.
If output intensity delivered by the computer adapter is higher than the output intensity of the HD adapter, chances are you have blown out a fuse inside the HD enclosure (if you have a fuse)
In addition to voltage, intensity, there is the question of polarity of the adapter (positive inside ---C+ or positive outside ---+C. You can verify compatibilties of the adapters by comparing the C with a dot on both adapters.
Hope it helps sort things out a bit.
Sep 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Ac adapter
My first thought is "yes" as long as it says Toshiba on it, but if you have one that fits, check for the same wattage, and amps. The whole thing could go up in smoke even if the adapter has the right voltage - if the amps supplied by the adapter are too high.
Thanks,
Mark
Aug 18, 2008 | Computers & Internet
DC power adapter
The adapter for the DE-805TP supplies 9 volts dc at around .5 amps
Jan 13, 2008 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
Open Questions:
See all BafoTech BAFO USB 2.0 Storage Cabinet Questions
BafoTech BAFO USB 2.0 Storage Cabinet Logo
132 people viewed this question
Top BafoTech Computers & Internet Experts
 Mike M
Mike M
Katie White
Katie White
Level 1 Expert
Are you a BafoTech Computer and Internet Expert? Answer questions, earn points and help others
