Question about Tools & Hardware - Others
How to put on the safety pad on a bosch sb2in1 nail gun
SOURCE: dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Posted on Dec 04, 2008
jj505
  • 195 Answers
SOURCE: staple,nail gun, how do i install the nail properly
SHOULD BE A SPRING LOADED TAB LOCATED USUALLY AT THE REAR OF THE GUN. PRESS IN THEN DOWN AND SOULD POP OUT SO YOU CAN LOAD.
PLEASE RATE
THANKS
Posted on Mar 20, 2009
  • 384 Answers
SOURCE: My nail gun will shoot one nail then stop. Any
I had the same problem with my Stanley stape gun. Had to replace all the seals and piston. Works find now! Check-out internet ...search for a rebuild kit for your model of gun. Get the complete rebuilding kit ....take about 1/2 hour to rebuild.
Posted on Jun 12, 2009
SOURCE: Arrow ET200 nail gun only put nails in 1/8 of inch.
I solved the problem. I took the nailer outside and plugged it into the outlet on my electrical post. It worked perfectly. I was not getting enough power from the outlet I was using in the house.
Posted on Jul 24, 2009
rcalorisian
  • 313 Answers
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
Posted on Sep 08, 2009
I have a Hitachi NR83A3 framing nail gun. It won't drive nails flush. Adjusting the depth screw from one extreme to the other doesn't appear to help or change the driven nail depth. Any ideas?
Easy to check. Remove nails from gun and connect to air supply. Using hard rubber pad or soft wood depress and hold trigger and push nailer safety against pad and hold there. The gun will fire but the driver will stay down until you pull back on the gun and relieve pressure on the safety foot. With driver down examine the tip of the driver. It should look square and should extend about 1/4 inch or more past the nose. If tip is broken replace driver. If lots of air is leaking past the nose during test, also replace the lower bumper. Good luck
Dec 23, 2014 | Hitachi Air Tools & Compressors
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
It won't shoot out any nails...pressure is 108psi,nailer has a few drops of oil in it,nails are placed on lower part of the slide
Are you applying downward pressure to the nail gun against the item you are attempting to nail? Many nail guns have a safety feature that requires the nail gun to be pressed firmly against the object.
Feb 28, 2011 | Tools & Hardware - Others
Nail gun will not shoot and air is exhausting out top vent all the time.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Garden
Framing a 2x6 wall
does the nose piece go back as far when you actually use the gun as when you pulled it back? I had the same problem with a different model, The nose piece acts as a safety to stop the gun firing when not up against whatever you are nailing. If it a similar design to mine (and most are) if you follow the nose piece up the gun somewhere along that will be some sort of bend in the metal to form the safety. it sounds like this needs to be bent a little more so it actuates the safety off valve/switch. Be careful though that safety is there for a reason, dont bend it too far and make the safety too sensitive. Hope this helps
Pete
Oct 26, 2008 | Stanley Bostitch F21PL Nailer
Arrow ET200 Electric Nail Gun
This is a known recall due to electrical solinoind malfunction,be sure to return before 90 days.
Please rate. Thank you. jj505
Sep 26, 2008 | Arrow ET200 Electric Brad Nail Gun
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Aug 27, 2008 | Bosch 18V Cordless Planer 53518
Nail Guns Safety problem
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Nail Guns costs
Aug 27, 2008 | Arrow ET200 Electric Brad Nail Gun
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
