Question about Makita Saws
How do i replace guard on makita 5704r circular saw?
How do i repace guard on makita 5704r circuar saw?
outdoorsman5
  • 631 Answers
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Posted on Jul 29, 2009
brewerstool
  • 141 Answers
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Posted on Sep 28, 2009
Testimonial: "Got it. Thanks"
rowdy45176
  • 2176 Answers
SOURCE: I have a makita circular saw 5704r. I droped the
it is a retaining ring and you need a special pair of pliers to remove this. If the guard is sticking remove the blade and lube and try and blow out with compressed air, if other let me know and I will try and help.
Posted on Jan 31, 2010
rowdy45176
  • 2176 Answers
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Posted on Feb 03, 2010
SOURCE: Instructions or diagrams on how to replace a power cord
saw just quit,fairly new ,light comes on ,so theres power
Posted on Jan 06, 2011
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Replace spring for saw guard makita ls 1030
Remove the guard and holder assy and place it on a flat surface as you undo the screw you will see how the spring fits into the holder under the bracket and also the locating pin.
Apr 02, 2013 | Makita Saws
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do i replace my tension spring on my makita 5007F circular saw? i put it on but it keeps falling off. what step am i missing?
is the spring stretched?? there are 2 holes one in the lower guard and one in the upper guard assembly towards the back that you have to put the bend of the spring in
Oct 02, 2010 | Makita Saws
SPRING LOCATION FOR BLADE GUARD
go to a store that sells the one you have and look at a new one . some wrap almost around the guard and some don't
May 01, 2010 | Makita 18V LXT Circular Saw
The return spring for the blade guard on my Makita 5630D cordless circular saw came off. It is attached to the blade guard, but I can't figure out where it attaches to the saw housing. Any hlep would be...
Feb 01, 2010 | Makita Saws
Jan 30, 2010 | Makita 7 - 1/4 & 34 Circular Saw Kit
Saws Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
