Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop won't connect to internet
My Toshiba Satellite laptop crashed, then when I re-started it, it recommended starting windows in recovery mode. I let it do what it recommended. Now it sees my rounter, but will not connect to the internet. Thanks for the help.
    President:
  • 1,214 Answers
You probably need to set-up security on the laptop. Security is used to allow the router to know who the laptop is.
All previous settings were lost when the recovery process was started.
Posted on Jan 20, 2009
Toshiba L300 crash and recovery disk will not install message says 'no RAID'
From your description the hard drive has issues, I recommend having it tested for possible replacement.
Jul 20, 2012 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite L305-S5875 always crashes on a cold boot.
Part of the problem is the hybernate function it causes windows to become unstable and eventually will corrupt the windows files making vista unusuable. I strongly suggest the hybernate mode be disabled and you make a backup recovery disc just in case windows crashes. By following what I have recommended and shut down windows when not in use will make a big difference in stability.
Apr 22, 2012 | Toshiba Satellite L305-S5875 Notebook
Toshiba Satellite L505 series laptop would not open windows
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Thanks
Feb 19, 2010 | Toshiba Satellite L505-S5966 Notebook
I have a toshiba satellite pro 4600 series that has recently crashed.I was able to get it back on the internet but can no longer can download anything. does anyone know how to resolve this issue?please, I...
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Select Internet Explorer 8
Click to "uninstall"
Restart your computer.
You'll go "back" to Internet Explorer 6 or 7.
Try NetZero again.
Nov 19, 2009 | Toshiba Satellite Pro 4600 Notebook
TOSHIBA A30 SATELLITE. WON`T BOOT, DOESN`T MATTER WHAT I DO. HAD TRIED RECOVERY CD`S , START FROM NETWORK,FROM PARALLEL...I THINK PRETTY MUCH EVERYTHING...AND NOTHING. RIGHT NOW, AM CLUELESS. THINK IS THE...
Put your Windows disc in the disc drive.
Tap F12 when the computer is starting up.
Select load from disc.
Install Windows.
It seems to be the only solution to your problem.
Hopefully, you made a partition and saved your files onto there, or onto an external hard drive to prevent data loss.
Jul 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Not booting up
Unfortunately you Windows OS crashed. Try pressing the F8 once you boot up. It should lead you to an option screen where you will be choosing SAFE MODE only. If you can boot up to windows under safemode you can do system restore or uninstall the program you just installed.
If you can't go into safe mode. Use the recovery disc. Pop disc 1 then upon booting the computer, press F12 to load boot menu then choose the dvd/cd drive. Once it finished loading, choose advanced option instead of Toshiba recovery wizard and it will lead you to system restore.
If both of the steps failed, unfortunately, you need to do full system recovery. Just do step 2 and choose Toshiba recovery Wizard, Out of the box state. This will delete all your data.
hope this helps.
Sep 12, 2008 | Toshiba Satellite A45-S151 Notebook
Toshiba Satellite A15 problem
Most Windows XP Blue screen errors are
reolved by the following.
Run CHKDSK /R
Do this by opening "My computer"
Right click on the C: drive (most often
named "local Disk") and select
properties.
Click on the Tools tab.
Click on "Check Now"
Check "Automatically fix file system
errors" and Scan for and attempt
recovery of bad sectors"
Click Start and then "OK" on the error
that comes up.
Now reboot your computer.
This will probably fix the error.
Mar 12, 2008 | Toshiba Satellite A15-S157 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
