Question about GE Profile JT965 Electric Double Oven
Microwave on ge jt 965-30" does not heat
All controls seem to work, sounds like it is cooking but product does not get hot
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: my GE double wall oven model #jkp86sh4ss, the
Hello & Welcome to FixYa
Checked the model no.and so the problem seems to be with two different parts not one. The problem that Microwave won't heat is caused either by a bad thermostat or a bad gas sensor. However, after reading your question it seems to be thermostat which is part#463 in this diagram. Another issue when the oven won't heat is caused by a bad oven temp. sensor which is part#253 in this diagram. Hope you understand both elements cannot be bad at the same time and so replacing bad parts will solve this problem. Please get back to me if you have any other questions.
Kevin
Posted on Dec 21, 2010
SOURCE: RE: GE cooking center microwave JKP85 - there is
I have exactly the same problem. I take it no one has offered a solution to this. Don't know if this is a lining coming loose and potentially dangerous. Anyone know?
Posted on Jan 31, 2011
Not heating
My oven lights but takes ages to cook food. Also flame goes off if oven door is closed at the beginning of lighting the oven
Dec 16, 2013 | GE JTP45 Electric Double Oven
GE j TP 86 oven wont heat
sounds like the hi-limit switch
Mar 02, 2013 | GE JTP86 Electric Double Oven
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Jul 05, 2010 | GE JKP85 Electric Double Oven
    Convection works but Microwave does not heat
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    duid
    May 26, 2009 | GE Monogram® ZMC1095BFBB /...
    Oven unit not heating up - Kitchenaid KEMX377GWHO
    This sounds like a blown thermal fuse, a common problem. What model oven was this?
    Dec 02, 2008 | KitchenAid Architect® KEMS378S Electric...
    GE Advantium Microwave portion not working
    There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
    Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
    GE Profile JT965 Electric Double Oven Logo
    42 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
