Question about Proform Walking Belt For The 727i Treadmill. Model Number: Pftl71230
Proform 727i incline - Proform Walking Belt For The 727i Treadmill. Model Number: Pftl71230
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Posted on May 17, 2012
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Incline trouble.
You most likely have a wiring harness problem. Get parts at usedtreadmillrepairparts.com
Dec 25, 2013 | Proform 7.0 Crosstrainer Treadmill
Proform 860 treadmill, want to undo incline feature, & use it without it
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
Proform 995 sel will not incline
Try calibrating the incline.
Start the machine. While the machine is operating, press and hold the incline up button. Remove the safety key. Now replace the safety key. The treadmill should go to full incline, then back to the bottom. Once the cycle is complete, the machine should work normally.
Feb 26, 2011 | Proform Exercise & Fitness
Proform xp650e, incline driving continuosly in max incline position with loud clunks/bumps
Your treadmill has what is called a "stair step" incline motor. It is common for them to go bad. You would need to remove the motor hood and activate the incline motor. Check to see if the noise is coming from the motor and if so I would suggest replacement.
Jul 28, 2010 | Proform Exercise & Fitness
I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 19, 2010 | Proform CrossTrainer Treadmill
Proform 740CS runs okay but the incline does not
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Proform treadmill CR610 won't incline
Open the cover where the main motor is there
Tight the connector for Incline motor, and clean it with special contact cleaner for electronic.
2) See if there are wires loose,
3) Measure the 110 vac for forward and backward,
4) If there are , measure the l. switch or Capacitor for faulty and replace.
5) If there nOT 110VAC in forward or backward, replace the controller board motor.
6) If there are 110VAC, replace the Incline motor.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 28, 2017 | Proform 675 Crosstrainer Treadmill
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Proform Walking Belt For The 727i Treadmill. Model Number: Pftl71230 Logo
51 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
