Question about Bosch SHV46C03 Built-in Dishwasher
Bosch she4apo2uc water inlet - Bosch SHV46C03 Built-in Dishwasher
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 11, 2009
Bosch washing machine error f17,any solution ?tks
That's an inlet valve fault. Either there is actually a problem with the inlet valve or the water supply is turned off or the inlet pipe is kinked and stopping water getting in
Aug 22, 2016 | Bosch Washing Machines
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Sgu 5602
If you are able to select wash programs and the panel is responding then most likely the water inlet valve is faulty and needs replacement. I am assuming you are hearing a click but no water comes through. Also check the inlet water tap under kitchen sink.
The valve for your dishwasher should be like this
http://www.bosch-home.co.uk/store/product/Valveaquastop/00263789
However, the problem can be more complicated if your dishwasher uses water softener unit. Will need the full model number to verify this. For example SGU5602/xx
You can also view all the parts at this site http://www.bosch-home.com/us/store/spareparts/Dishwashers60cmbuiltinbuiltunder/SGU5602/03
Apr 22, 2014 | Bosch Dishwashers
Dishwasher will not fill with water when turned on
Hi and welcome to FixYa, I am Kelly
The following steps require using electrical power. You assume all responsibility / risk for any mis-fortunes cause by working on this dishwasher with power applied.
The first step will require using a meter on the water valve solenoid teminals.
- Remove all power.
- Remove the lower toe / kick panel(s).
- Locate the main water supply line and follow that to the inlet water valve.
- Slide the connector(s) off of the solenoid and read resistance on meter scale R x 1 or R x 10. You should read a low resistance. If you do not read any resistance the inlet water valve has failed.
If you do read resistance you must check switch the meter to AC voltage and apply power and read for AC voltage on the teminals of the wire harness.
- Start a reular wash cycle to where the unit should be filing with water.
it SHOULD read 120 VAC.
If you have no power at the connector teminals
- Check the float switch plastic FLOAT. If the float is stuck in the UP position due to food particulate on the FLOAT stem you willnot have power to the inlet water valve solenoid.
If you have power to inlet water valve solenoid and it is buzzing / humming but you get no water there is debris in the main water supply line. You wil have to shut off the water supply and clean out the inlet of the water valve.
The inlet water valve replaement part is here:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=233229
Detailed View
http://www.appliancepartspros.com/Appliance-Parts/bosch-water-inlet-valve-assembly-item-number-ap3783031.aspx
This is what the float looks like:
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-item-number-ap2802399.aspx
This is the level switch assembly:
http://www.appliancepartspros.com/Appliance-Parts/bosch-level-switch-assembly-item-number-ap2802390.aspx
This is the actual Float switch: (3 terminal)
http://www.appliancepartspros.com/Appliance-Parts/bosch-float-switch--3-terminal--item-number-ap2802373.aspx POWER to the inlet water valve solenoid comes from this switch.
Check for s stuck float... and that the level switch is actuated as the float id lifed gently up and down. If you do not hear a micro-switch click the switch is bad. If the float is hard to move... clean it as best you can so that it moves freely up and down.
One of the above is causing your problem.
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | Bosch SHU9915UC Dishwasher
Just installed the dishwasher. When trying to start it, we get an E-23 message
Hi.
If we are talking about a Bosch, Siemens, or other Bosch built dishwasher, E23 means inlet error. Check water inlet hose and pressure from the line. Test inlet valve. If water is getting into the appliance, test the water level switch.
May 08, 2011 | Dishwashers
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Hope this helps... Please post back if you need more information
Daniel
Nov 10, 2010 | Bosch SHU5315UC Dishwasher
No water inlet on dishwasher
the water inlet is controlled by an electronic valve, which sounds like it is faulty.
Apr 30, 2009 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch S9GT1B not taking water
check electro valve,water-level switch.
Feb 15, 2009 | Bosch Dishwashers
Bosch exxcel 1400 s express fault F01 and F02 whats the problem here?
F01 Door not closed properly.
F02 Tap not turne on, Inlet hose kinked or pinched, Filter blocked in water inlet hose, Water pressure to low.
Apr 30, 2008 | Bosch Washing Machines
Bosch SHV46C03 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
