Question about Samsung Washing Machines
My swan sw3010b is displaying error code OE and the door won't open
My washer keeps displaying error code OE as soon as it gets to the rinse part of the cycle. the door lock will not release even with the power turned off
  • 90 Answers
SOURCE: Door Lock won't release.
pull your wire in soap dispenser to open door. You may have crimped a wire at door latch assy. when lowering top.
Posted on Jan 07, 2008
MNTECH
  • 1543 Answers
SOURCE: error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Posted on Oct 15, 2008
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
SOURCE: MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Posted on Mar 12, 2010
rickead1
  • 1998 Answers
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Posted on Jul 04, 2011
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
THe machine won't rinse. Displaying a "OE" symbol
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jul 26, 2011 | LG Washing Machines
Displaying oe
LG's 'oe' stands for Open (door) Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 25, 2011 | LG WM2301HW Front Load Washer
Machine gets stuck in rinse cycle - sometimes gets OE code sometimes not.
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the front bottom for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | LG WM2455 Front Load Washer
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
Error code oe
Oct 15, 2008 | LG WM-1485FHD Front Load Washer
My lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing displaying OE error code
here's a link to a service manual for you particular model seems OE is an overflow error, this will help you trouble shoot your problem. ( im current ly downloading this manual for my own reference )
http://www.servicematters.com/maytag_library/docs/16026186.pdf
Mar 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
66 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
