Question about Whirlpool Hardware & Accessories
Instalation instruction for timer on model LSR5233ANO
How to remove and install timer on whirlpool washer LSR5233ANO with part no 3358741B
  • 4 Answers
SOURCE: installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Posted on Nov 21, 2007
mikedurland
  • 481 Answers
SOURCE: whirlpool washer timer
no magic to it, but double check your wire harness and make sure it is plugged in all the way. it is sometimes easier to plug the harness in before mounting the timer to the control panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 22, 2008
onthejob5130
  • 640 Answers
SOURCE: whirlpool duet washer tub bearing
wow ,,that unit must sound like a jet ..this is a job,,i can talk you though but i cant tonight,,if you can wait i will help tommorow at 6 after work..if you need a little head startgo to cematters.com
Posted on Jan 09, 2009
SOURCE: replace timer on Maytag washer
I no longer need your service. Thank you.
Posted on Jan 13, 2009
  • 1937 Answers
SOURCE: Installing a whirlpool cabrio washer lid switch.
See the following Whirlpool Service Manual for the Cabrio.
This should help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Posted on Nov 10, 2009
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Whirlpool washer timer
Please check the wiring as you might have not hooked up the connectors for the water valve.
Jul 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Timer setting
this model doesn't have a timer. it is computer controlled.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Kenmore washer model 110-20712991. the timer doesn't advance. Wherever I put it, it stays there and only does that functions, never advancing to the next position. Is there any test i can perform...
It does sound like a bad timer:
See the following: This is a Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has testing instructions as well as directions for removing each of the two types of timers.
If your timer is the one with a knob that un-screws, use a thin needle nosed pliers to hold the shaft going thru the timer while you un-screw the knob.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 12, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool Ultimate Care 3.0 Heavy Duty LSL9244EQ/Z Washer. The water fill overflows when turned on and will not advance the timer. I manually moved the timer to see if the machine would wash....
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Sep 08, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Instructions for installing timer part number 8541110 for Kenmore elite wash machine.....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the following for how to release the console for access to the timer.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has troubleshooting and testing procedures as well as a description of the TWO types of timers. Each has different procedures for replacing them.
If yours is the metal type, the procedures call for unscrewing the timer knob before it can re removed.
You may need to use a thin needle nose pliers to hold the shaft on the back side of the timer in order to unscrew the knob.
May 08, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
Washer Doesnt Change Cycles
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 washer, does not move from one cycle to another
I'd also look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
Sep 26, 2009 | Kenmore Washing Machines
Hardware & Accessories Logo
56 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
