Question about Emerson (025806803716) Wine Cooler
Wine cooler making a buzzing noise - Emerson (025806803716) Wine Cooler
2 Suggested Answers
  • 5 Answers
SOURCE: We have our wine cooler for less than two years.
It is not the compressor. This unit uses a peltier cooling system. It has no compressor. It relies on applying a voltage to two dissimilar metals connected at two junctions and when this is attached to a heat sink, allows for the cooling effect. I know this doesn't help, but I thought I should point this out.
Posted on Mar 25, 2010
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
Fridge makes a fairly loud popping noise at intermittent intervals...otherwise works fine and maintains wine temp as set....makes this noise approx 10-15 times a day....unable to determine any set pattern...
What you are hearing is the new refrigerant going through the system. The old Freon 12 did not make that noise but the new stuff does. Nothing to worry about, it is normal. Thank you for using Fix ya and I hope you found this info helpful.
Jun 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
Making noise
not to many moving parts on that wine cooler more then likley it is the compressor making the noise. check your warranty to see if the compressor is covered
May 12, 2011 | Haier BC112G Wine Cooler
My Danby wine cooler fan is making a horrendous noise - it sounds like it's trying to start up and then it gives up. I hav tried tightening the housing screws but this works for a couple of minutes and...
Where is the noise coming from? Check the fan at the back of the upper compartment. They seem to be defective and die after about 3 years (just outside of warranty... how convenient). I'm dealing with the same issue now. (As search on the internet indicates that we're not alone!) When its making that noise, try pressing the back plate around the little fan and see if it changes the noise.
Apr 11, 2011 | Danby DWC283BLS Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Emerson (025806803716) Wine Cooler Logo
64 people viewed this question
Top Emerson Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Emerson Furniture Expert? Answer questions, earn points and help others
