Question about Toshiba 43H70 43" Rear Projection Television
Flickering of screen (comes and goes) and weird DVD/reception problems
Okay I bought this tv used, and everyhting was fine until I started getting this weird black flickering lines on the screen. The picture is still fine and clear. The flickering comes and goes. Sometimes it's there and then won't come back for weeks, very strange. It might be a connection problem inside, here's my next issue. I had a dvd player plugged in the a/v cables, it worked fine and then all of sudden i got sound and no picture, so i bought a dvd player and it worked fine as well, then the same thing happened. I tested the new one on my friends tv and it works fine. i don't get it? lastly, i think my coax cable things are loose. sometimes the reception goes blurry/distorted and i need to jiggle the coaxial cable thing. how do i tighten the loose connection? I'm sure this all connected, but i don't want to open this thing up and break it. so, i need help figuring out why my tv flickers black lines at times, dvd players that work and then don't, and how to tighten the loose coax/coaxial cable connection? Thanks.
  • Jonah Wine Jun 29, 2007
    Hyper board? sounds complicated? can it be fixed? where do buy one of those? the set is like 10 years old.
    It works great just sometimes it has it's problems.
  • Jonah Wine Jul 02, 2007
    I think I can probably squeeze another year or 2 out of the set and then junk it. The thing is it's so goofy, because for the most part it works great, awesome tv. i only paid $200 for it.
    Thanks.
    President:
  • 3,130 Answers
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Posted on Jun 29, 2007
  • Larry  Dillon
    Larry Dillon Jun 29, 2007
    There are bad capacitors in the set also i bet, probably not a fix that would be worth repairing, as the board is about 250 to 300 bucks, but the problem is they are no longer available.
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Flickering Screen
please change the INVERTER card of the screen of your laptop
Jun 02, 2010 | Computers & Internet
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Is it the TV or Comcast?
I'VE SEEN QUIT A FEW SAMSUNGS DO THIS AND THE DIGITAL BOARD IS THE PROBLEM YOUR MODEL NUMBER DOES NOT HAVE A DASH HLR4667W AND YOU NEED YOUR VERSION NUMBER AND MAYBE THE BEST THING IS GET THE PART NUMBER OFF THE BOARD.
Apr 17, 2009 | Samsung HL-R4667W Rear Projection...
Monitor
That's better.
Yep, 95% chance it is the power inverter problem.
If you don't remember the screen having a pink tint or flickering for a while or being dark at the middle top or bottom before it went, then your bulbs should be okay.
It will need at least all the capacitors replaced.
I fix many of these types on ebay.
bammbammfran
Oct 15, 2008 | Computers & Internet
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Toshiba 43H70 43" Rear Projection Television Logo
181 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
