Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
GE Profile model pfss5njwass + water not working
Door water not working. I can hear the motor working when I press the paddle, but no water is coming out. The panel works (lights are on, they beep when i push them, etc.)
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
SolutionGuy
  • 331 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
  • 103 Answers
SOURCE: How do I remove the ice/water access panel on GE
First, open door to freezer, while pushing in on the ice dispenser trigger look at the lights in the freezer and see if they go dim, if they do then the "main board" on back of frig is defective. This is a common problem with these boxes. Its somewhat uncommon for the ice, water and light to go out at the same time, its possible, but not common.
Another way to tell if main board is bad is when you do as stated above and you hear the evap fan stop then main board is for sure bad.
Let me know what you find out. If main board then I will need model & serial number to give you the right part number for main board.
If none of the above occur, then advise and I will tell you then how to pull dispenser apart.
Posted on Oct 10, 2009
PeteG0429
  • 34 Answers
SOURCE: my ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Posted on Feb 20, 2012
Dispenser door opens, but auger motor doesn't operate for cubes or crushed ice.
I believe that voltage to the auger motor should be DC voltage. Yes it could be a relay on the board causing this and it could also be the Auger Motor 2252130
APPLIANCE 911
Dec 06, 2015 | Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Apr 25, 2015 | Refrigerators
The refrigerator makes 6 beeps after dispensing water. Everything seems to be working normally so I do not understand why it beeps after the paddle returns to its normal position.
Apr 05, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Water and ice dispenser stopped working
You will need to replace the dispenser control board on the door. Here is the part to order.
Dec 08, 2012 | GE Refrigerators
Have ice but no water. Changed filter and can hear water filling filter. Front control panel operations intermittent at best. Light in dispenser not working.
what is the model number?also try pushing crushed ice or cubes,just worked on a g.e. and the control panel on the door was bad,it kept beeping and if you pressed crushed ice the water would work,had to change out the board on the door,send model number so i can look it up for you,if you can hear the water fillling up in the filter it could be the board or a frozen water tank line,remove the bottom draws and see if you can see the water tank,with a hair dryer heat up the line where it connects to the tank if your model has a tank,send model number
Sep 26, 2010 | GE Refrigerators
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Doors wont all lock at the same time on my '95 saab 9000cs. i have to manually lock them individually. My dashboard lights flicker, sometimes the lights will stay on and sometimes i have to tap the switch...
When you use your remote or insert your key in the Drivers Front door all the door locks should work at the same time by the door lock motors electrically. If you have to manually unlock the door because it will not lock or unlock by the lock motor, you need a door lock motor. The drivers and passengers front doors can unlocked with the key manually only. The rear doors you have to pull up the latch.
If NONE of doors unlock electrically with the remote or drivers door lock, intermittently or all the time, you will need a Central Locking Electronic Control Module. Pressing the remote button you will hear the "beep", but no door locks will fire at all.
If you have a few odd door locks not working intermittently or not at all, you will need a new door lock motor for each door lock that malfunctions. You can hear if the door locks are working electrically. Yes, they are common problem.
If you can hear the door lock motor working but the door still doesn't unlock you need to take the door panel off and lubricate the door latch assembly and work the lock, loosening it up. This is common as well.
Sometimes a bad door lock motor can blow the central locking fuse. You will notice it because it will take a second or two longer to lock and unlock compared to the others. If the door lock motors seem fine, install a the next step up in amperage fuse. (From 15 AMP to a 20 AMP)
Apr 09, 2009 | 1997 Saab 9000
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Open Questions:
See all GE Profile PDS22MHR Bottom Freezer Refrigerator Questions
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
64 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
