Question about Sony SDM-HS75/B 17" LCD Monitor
MONITOR SCREEN GOES BLACK AFTER 5 SECONDS
I can repeatedly turn monitor off and backon again, and monitor screen will display for about 5 seconds, then go black again.
SOURCE: KF 42WE610 turns on for two seconds, then goes black
no, had the same problem. Its the lamp ballast also called the lamp power block. It supplies power to the lamp, any how some repair shop wanted $450 to fix it, so i ordered the part from sony, part #146879816 ($116.25), trust me this is the part I double checked with many different places. Any how fixed it my self took about 15 minutes, just take the back cover off and the part is right there just kind of follow the screws and the 3 wires, super easy job, I suggest you replace the bulb at the same time, dont by a cheap bulb just get it from sony
Posted on Jan 23, 2008
  • 11 Answers
SOURCE: KDF-E55A20 red light blinks 5 times
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV. if this does not work it is time to replace the bulb.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
jewellgirls
  • 12 Answers
SOURCE: Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Posted on Oct 16, 2008
  • 37 Answers
SOURCE: Samsung lCD monitor displays for 1 sec
This sounds like the backlight in your monitor has gone. I have seen this a bit in samsung LCD's. You can usually tell this by getting a torch and shining it on your screen. By doing this you should be able to see the display on the monitor.
The first thing to do is check the monitor is under warranty. Samsung have fairly lenghty ( 3 years i think) warranties with them. If it is under warranty they will replace it no questions asked.
Otherwise, you could try your hand at replacing the backlight yourself. I'm not too sure of what is involved in this, but know of people who have done it and said it was fairly easy.
I hope that helps, please don't forget to rate my answer if it does.
Posted on Mar 20, 2009
SOURCE: TV turns off/on
I had the same problem on my TV (had it for 2.5 years) tried to clean the bulb, but it still did the same thing. So i replaced the blub and the problem went away and the screen is brighter now. Sometimes it just about that time to replace the blub anyways.
Posted on May 05, 2009
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Monitor backlight problem (Dell S2409W)
pa_ma_fi, Have you figured out how to do the flashlight test on you monitor when it's lcd panel turns black or blank n black. No, CCFL back-lit lcd monitors require lots of things to be working all together at once to light up the CCFL tubes. The new style curlie-Q screw-in, energy efficient CFL light bulbs are of the same similar technology and use an "electronic-ballast" circuit to "light-up" the lamp! You will need to check to see if pc is working perfectly with old monitor that you know is good. You should do some free reading here at fixya in my and other fixya ccfl back-lit lcd technicians profiles. ou will also need to visit YOUTUBE for "LCD monitor disassembly" and "LCD monitor repair" videos. May need printed circuit board "switch-mode-power-supply/ ccfl inverter supply " to be repaired If pc software/firmware has been determined not to be causing this on/off/on/off symptom.
12fixlouie
Apr 29, 2010 | Computers & Internet
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Sony SDM-HS75/B 17" LCD Monitor Logo
22 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
