Question about Daewoo DSP4210GM 42 in. Plasma Television
T.V.Connection We have a 14" Daewoo T.V in the bedropom, and we have bought a new video set, how do I get a channel to play the video (I am 77 years old so let's hope it isn't a complicated routine!) thank you
  • margaret_rid May 11, 2010
    First of all it was a 14" Daewoo T.V. not 42" and I still don.t know how to get a channel on the T.V. for my video set. I am 77 years old ,so as you can imagine everything is a mystery to me!!
    Margaret
    President:
  • 2,976 Answers
By video set, I'm assuming you mean a CD/DVD player or a VCR. Normally, these are set to play on channel 3 or 4. Connect the cables that came with it either according to color, or if it just looks like one round cable, connect it to "OUT" on the player and "ANT" on the TV. If you have the colored plugs, Red out to Red in, Yellow out to Yellow in, White out to White in. Turn your TV to one of these channels and try the player. If it doesn't work, try the other channel. When you get it working, you will probably have extra wires. They're to allow for different types of installations.
Posted on Mar 05, 2009
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
I want to set up my video recorder to my tv and have forgotten how to do it. I have connected the two by aeriel but cannot see what else to do.
Youe aerial should be in the rear of the VCR & the other cable (flylead) should come from the output connection of the VCR & into the TV. To easily find the VCR channel insert a film tape into the video & press play, now selecting the VCR channel on the TV (EG. channel number 0) now you will need to go into the manual tuning on the TV & search until it finds the playback film, once this happens, store this setting. An easier alternative would be to buy a scart connector & connect this from the VCR to the TV & then the video channel will show on the AV setting on the TV, this saves you any tuning problem.
Oct 14, 2009 | Daewoo Televison & Video
13 TO 14 YEAR OLD SANYO TV SHOULD I GET IT FIXED
You try to play the video tape or DVD. If picture still snowy, the picture tube is getting old. Buy a new one, do not repair it will cost almost a new set.
Aug 12, 2009 | Acer Aspire One AOA110-1588 Notebook
Setting Radio Channels
press and hold the button you want to designate for the station you want to program...hold until the screen flashes or beeps at you...you're done!
Good Luck
Jun 14, 2009 | 2001 Daewoo Leganza
Starview box code
codes as from today ,nov 24th uk and n ireland 00 / F6 51 AA 63 14 78 B9 77 / 01 / 2E F4 DA O6 D9 4C 8C 40 these code will work
Nov 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Toshiba D-VR610KU recorded disc won't play in my Daewoo DVD5800
What are the compatible types of DVD's that the Daewoo DVD5800 player is supposed to play? Is DVD-R among the compatible types? Try playing the new recordings on a computer that has a DVD drive, or a friend's computer.
Apr 20, 2017 | Televison & Video
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Connection Nightmare
try here in this forum http://radioandtelly.co.uk
they will give you some ideas t oconnection set up .
riz.
Nov 02, 2007 | Daewoo DVDRW11 DVD Recorder
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Daewoo DSP4210GM 42 in. Plasma Television Logo
75 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
