Question about Toshiba Computers & Internet
Toshiba satellite c855d-s5320 laptop cursor won't move or click
Cursor won't move or click
PABLOCSA
  • 1124 Answers
SOURCE: Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Posted on Oct 27, 2008
SOURCE: toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Posted on Jan 31, 2009
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
anjana03
  • 361 Answers
SOURCE: cursor moves, wont click!!
i think there may be two reason.1/some setting may be worang-go on conttrol panel and chose printer and other hardwere. inside click mouse and look setting.2/ your touchpad driver may not be working properly. stall it next.
Posted on Jun 12, 2009
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
Posted on Jul 23, 2009
DVD player has sound but no picture
Here are solutions:
  • Buy a drive cleaning CD/DVD, those from dollar store may also work, clean the drive a few times and it should read CD/DVD.
  • Alternatively look at the Toshiba support drivers for firmware update to your specific drive. Make sure you do get all the recommended and critical Toshiba updates. Check it here: http://support.toshiba.com/support/home
Regards, Mike Official Toshiba Support Toshiba
Oct 25, 2015 | Toshiba Satellite C855D-S5320 Notebook...
How do I replace hinges on Toshiba C855D-S5320 Laptop?
When I need to replace hinges I locate the service manual, not the user manual, for the laptop I am repairing and they have detailed instructions on dis-assembly for repair of most components inside the laptop.
Oct 06, 2014 | Toshiba Satellite Computers & Internet
How do i fix rtc battery low press f2 key to set date/time but the keyboard does not respond
Replace the CMOS battery. Now known as the RTC Battery.
(Real Time Clock)
I believe 6C372759Q is the -> Serial Number
Toshiba = Manufacturer name
Satellite = Model Series
C855D = Model Series number
S5203 = Model number
Toshiba Satellite C855D-S5203
The above info just tells you what Toshiba laptop it is. NO personal information.
What you did was good for me, bad for you.
Explanation; In the old days I read that a bad guy, would use the Serial Number to find out the person's name, and home address. Or the name, and address the computer was listed to have been sold to.
Then they would watch the house, and find the homeowners schedule. (Case the house) Then rob the house. They know for one, the laptop is there.
I believe that......makes sense......makes the hair on the back of my neck go up too!
(Also read, that if they can tap into your computer, and see that you have a calendar on the desktop screen, with appointments set; they have your schedule. Know when you will be home, or doctors appointment, kids to xxxxx practice, dentists visit, vacation, etc)
Yes, I will be alerting FixYa staff to remove it.
It was good for me though, so I can find out exactly what Toshiba laptop we're talking about here.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Buy, and wear an ESD wrist strap. Connect it's alligator clip to a good ground source.
Electro Static Discharge. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
You have to disassemble the laptop, in order to access the RTC (CMOS) battery. The RTC Battery is on the -> Bottom of the motherboard. Access is after removing motherboard out of Base Enclosure (Bottom Cover).
You have to disassemble from the Top down.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C875-C875D-C870-C870D/disassemble-laptop-case-1.htm
What makes me think the Satellite C875D is so close to the Satellite C855D, that I can post a disassembly pictorial guide for a C855D? The Base Enclosure (Bottom Cover),
http://www.ebay.com/itm/Toshiba-Satellite-C855D-Bottom-Case-V000271740-With-memory-cover-not-pictured-/330896862554?pt=LH_DefaultDomain_0&hash=item4d0afd6d5a
Here is a photo of the Bottom view of the motherboard. This is the side the Processor, and Ram Memory are installed, also,
http://www.ebay.com/itm/Toshiba-Satellite-C855D-Motherboard-AMD-Integrated-1-3GHz-V000275390-Tested-/330868111843?pt=Motherboards&hash=item4d0946b9e3
SET, your mouse cursor in the middle of the photo. This enables the Zoom In feature. Now move to the Right. See the round silver looking thing with the Blue dot on it?
RTC Battery. It's a watch type battery. Looks like a CR2032, as used in most desktop computers. HOWEVER, the number will be on the battery. May NOT be a CR2032. May be smaller.
Post back in a Comment if this is what you wish to do. If you want I will try my best to step by step you through it. If not peel off $75 to $125 for a computer repair shop to perform this.
(They get paid for their technical knowhow...Not how physically hard the job is..........)
For additional questions please post in a Comment.
Regards, joecoolvette
Apr 21, 2013 | Toshiba Satellite Computers & Internet
I own a Toshiba Satellite C855D and my HDMI port has a plate cover. How do i get it off?
Are you sure you actually have a HDMI port ad not just the area that makes HDMI optional when ordering or for after the fact installation of a new video card?
Jan 12, 2013 | Toshiba Satellite C855D-S5354 15.6" Laptop...
Does my toshiba satellite c855d have hdmi output
Hi Alex,
The Toshiba C855D-S5320 does. Can you confirm the type of C855D you have. With the description of the plate I doubt your model does. On the one I use, I knowingly gave up touch screen for HDMI with budget I had. I have it connected to a 24" ASUS screen and I'm very happy with HDMI. Good luck! Toshiba C855D S5320 Laptop
Jan 06, 2013 | Toshiba Computers & Internet
Is there a cover over the hdmi port on the toshiba C855D-S5359
According to Toshiba Website - there is no HDMI port on this model laptop.
http://us.toshiba.com/computers/laptops/satellite/C850/C855D-S5359/
Dec 30, 2012 | Toshiba Computers & Internet
Computers & Internet Logo
1,088 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
