2001 Audi A6 Logo
Anonymous Posted on Jan 07, 2013
Audi a6 quattro 2001 coolant disappears, engine overheats and white smoke comes out
Hi All, Few days ago I was driving for 20 mins after starting the car. Then all the coolant just leaked on the street. And I filled up the coolant container and when I arrived in front of my house after 10 mins of drive, it spilled all over the ground again. I then put stop leak in the container with coolant and followed instruction. Engine still was over heating and coolant disappeared this time did not spill all over the street. I then took it to the garage, but before I take it there I had filled coolant container again and once I arrived at the garage the coolant liquid was gone but I do not see it leaking. And engine eventually started over heating. Mechanic said the Radiator hose that takes to the expansion tank needs to be changed and that's the problem. But auto part stores were closed it was a saturday and he cut the current hose a bit and put some coolant liquid and stop leak and told me to see if it works out. When I reached my house coolant liquid disappeared again and engine was over heating. The day after I put some coolant liquid but did not drive and after few hours it disapparead but no sign of leak or it didn't spill on the street. IT CAN'T BE MAGIC CAN IT????
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 24 Answers
  • Posted on Jan 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
24
Questions
0
Helped
7782
Points
34
Unfortunate you're losing coolant into the cylinders, where it's being burned off and exiting out the exhaust. When you initially added that cold coolant into the hot radiator, and hot engine (sit down) you likely cracked the engine block. Best case you just need to replace the head gasket.
5 Related Answers
A
Anonymous
  • Posted on May 24, 2008
SOURCE: Audi Fuel Pump
is it fitted correctly? If it is not fitted correctly it will do this. Have you checked the relay?
Anonymous
  • 1586 Answers
  • Posted on Oct 01, 2008
SOURCE: audi engine oil leak?
Sounds like a leaking valve cover gasket. The parts are around $50 to do both cylinder heads from www.ecstuning.com. It's not a major issue, but it may be a sore point to a potential buyer.
Anonymous
  • 324 Answers
  • Posted on Nov 26, 2008
SOURCE: problems with my 1995 Audi A6 QUATTRO
replace the coil pack, sounds like it is over heating.
Anonymous
  • 297 Answers
  • Posted on Apr 14, 2009
SOURCE: Audi A4 2.5 V6 TDI - Creamy grey coolant in expansion tank
Sounds like blown head gasket (or worse) still to me.
Remove oil filler cap and look for grey oil.
Never use water these days but special coolant. Water makes vapour spots and cause block cracks, worse then blown gaskets!!!
vapour does not cool very well.
Look like you have cracks already.
Take a compression test if possible. But might not show op at that temperature.
The gauge indication troubles me.
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 28, 2009
SOURCE: AUDI A6 1999 USING OIL, NO OBVIOUS SIGNS
your engine needs to be compression tested
White smoke out of exhaust
Regarding 2001 audi a6 quattro 2.7t....i was driving to work the car was fine then white smoke starting coming from under the hood and tail pipe. i stopped veilce and alot of oil was dripping from front of car. I towed it home and i looked under the hood and there was oil from valve cover gasket. i let the car sit for a few days, had it running again for a good hour and no white smoke was coming out. I removed the valve cover and gaskets are all bad. i want to know can the valve cover gasket leak cause the white smoke to come from exhaust pipe?
1helpful
Engine overheats and heater blowing cold air
You have air trapped in system , change thermostat , bleed air from system , let it run hot while adding coolant with blower full blast on all front and rear heaters .
1helpful
I have white white smoke coming from under the coolant tank, when starting the car cold in the morning, driver side
I was going to say that white smoke wouldn't be oil but I see that you figured that out. Look for loose coolant hose clamps on or near the reservoir or possibly a small crack in the reservoir itself. As a general rule for gasoline engines: White smoke = coolant, Blue smoke = oil, Gray smoke = fuel, Black smoke = "Uh oh, that can't be good." :-)
3helpful
2answers
Why is my 2001 audi a6 is overheating 140,000 miles
Hi there:the Audi manual never talks about a 2 stage aux fan just that the aux fan runs with ac on and it can run with out ac on if there is an overheat issue on the coolant side where as the a4 info clearly states a 2 stage aux fan system that would lead me to think the early 4.2 did not use a 2 stage system. Your car is not overheating and boiling over out of the coolant tank it is showing a little hotter than what would be perfect but it is still in what Audi calls acceptable range. The whole coolant system is new I would start looking at your sensor and gage systems there is a coolant sensor in the rad but that is most likely new if they replaced the rad. The gage uses a temp sensor on the engine for the gage I would replace that sensor and test the gage with a resistance input tool we have at the dealer. Could be a gouge or the wiring to it. There is a coolant fan module that could be defective if your sure there was a two speeds to the aux fan.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
I have a 1998 Audi A6 2.8 Quattro with a damaged auto transmission. Car has been sitting for about 8 months without starting it. Today I bought a new battery and started the engine. I was careful to...
The engine could be damage. I have seen when the engine let's go break suddenly it smoking a lot. Do the following check oil level and condition, check coolant level and condition,
1helpful
2answers
I have a 2001 Audi A6 quattro, 120k miles, check engine light came on a few months ago and code said it was O2 sensor, this past week when i drive the car engine sounds really loud like it is revving...
i have a 2001 Audi A6 quattro 95,000 miles when i change gear the car seems to over rev or keep reving when i put my foot on the clutch for a split second chould you tell me why is this
4helpful
2000 Audi A4 quattro with abrupt gear shifting & low oil pressure
I hope that you had the proper weight oil installed, at your oil change. If your oil is up to the proper level, and it's rattling ,this is VERY bad. White smoke usually means steam in the exhaust, and that means a blown head gasket. Check your coolant level. I wouldn't drive it anymore......until someone knowledgeable can diagnose it!!!!!
Problems with my 1995 Audi A6 QUATTRO
3answers
Audi Fuel Pump
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
