Question about Drills
WHY IS MY MAKITA HAMMER DRILL LEAKING OIL OUT OF THE COLLER THIS JUST STARTED THE DRILL IS ABOUT 2YRS OLD
THIS PROBLEM JUST STARTED WHILE I WAS HAMMERING
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
brewerstool
  • 141 Answers
SOURCE: oil leaking from gear box on hammer drill
Where is the oil leaking from. By the chuck, or the selector knob, or is it leaking from where the gear housing meets the motor housing. I could be one of 3 things. There is a seal between the two housings that could be damaged, not likely though. There is an oring on the selector knob that can get worn, and there is a sealed bearing on the spindle that should not let any oil through. There should not be any oil in this tool for lubrication. Grease is used in this tool for lubrication. If you are getting oil or a liquidy type substance coming out it is more than likely the grease has broken down and needs to be replaced.
Posted on Oct 14, 2009
Biggdex35
  • 333 Answers
SOURCE: hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
Posted on May 30, 2010
  • 178 Answers
SOURCE: Makita 6935FD has lost all
Remove the brush caps and have a look at the brush length.
If they are extremely short, or barely touching the commutator bars on the armature, you will need to purchase a brush set part # (193466-2). The way you are describing it behaving without a load, and charged battery, I can only assume this will fix it. The other thing you can do is open the clamshell housing and with a pick, attempt to move the armature fan and see if it will make several full rotations. I want to know if a piece of the magnet ring broke loose and is rolling around between the armature and the magnet ring causing your varying RPM.
Posted on Nov 22, 2010
Makita drill burnt out
The motor is bad from overheating. Have motor rebuilt or replaced.
May 24, 2014 | Makita Hr3210c 1-1/4" Avt Sds-plus Rotary...
Makita
possible broken spindle or gear in the gear case
Aug 26, 2012 | Makita HR3851 Electric Rotary Hammer
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
The drill is leaking oil
As my knowledge drills not use oil just grease in the bearings.But if you need to service and the drill is not too old and the repair is not cost too much you can find parts at Hilti Online or by your self using the Hilti Manuals.
Nov 11, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
I have a 18 Volt Makita drill , model # BDF 452 which I've used only 3 or 4 times . The last time I used it , I could not remove the drill bit . The chuck will not turn/loosen to release the bit . Any...
oh I hate when that happens. ushally its due to not being lined up right inside the unit. happens with my cheaper drills more so then not.
I ushally just secure the bit into my vice, and then tap the the key with a hammer to loosen the threads..
sounds like she might need a bit of oil I ushally use air compressor oil just a couple drops work for me.
Aug 13, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Grinding noise
possible burnt out in the brush holder assy,checked the motor
Apr 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
586 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
