Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Sysem will not remoot fast and properly
My system will not boot fast it will say that insert system disk and press enter but i dont have mother board disk and after 30- 40 mnts system automatically will reboot but after booting while in net automatically system will restart, kindlay advise what to do
system details is as follows
intel (R)
pentium ( R )
cpu 2.66 ghz
    President:
  • 1,214 Answers
It sounds like you are having a hard drive failure.
The message your getting is not asking for the motherboard disk, it is asking for an operating system disk.
I don't understand how the computer ever get's to the Net if it can't get past asking for a system disk.
Please provide further information, such as operating system, how old the computer and hard drive are, and a more clear description of what the system is, or is not, doing.
Posted on Jan 20, 2009
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
MY PROBLEM IS THAT I DONT HAVE A MOTHER FORMATE DRIVES
if you are referring to a format on your hard drive
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope this helps you
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
Mar 29, 2012 | IBM Computers & Internet
How to format drive c in dos? i am using xp pro...can you give me the steps? PLS HELP I AM NOT FAMILIAR IN COMPUTER BUT I WANT TO DO IT IN MYSELF
Just boot from a Windows install disk (put the cd in, press the boot selection key and select the cd unit) and allow it to run: the first step in the process is selecting the drive (select C), the second one is formatting of the drive - select the regular one, not the quick. After that just pull out the Windows disk or let it continue.
Mar 11, 2011 | Computers & Internet
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Disk boot failure
Your boot sector is corrupted you need to install windows again from a bootable windows cd...
Feb 28, 2009 | Intel D845GVSR Motherboard
Problems during formating
You have to chose the driver for your operating system and create a floly disk with it.
To create a floppy disk boot with your motherboard CD and chose the option to create floppy disk (WINXP)
If you are using windows Vista you can directly chose drivers form CD.
Jan 14, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
