I purchased a canon ir c 3200 from a large company which had it setup on a large office network with their own IP address and other settings etc.
Therefore when I plug it into my network it does not communicate at all.
How do I reset and erase ALL settings on this printer to restore factory settings?
Thanks for your help
i have to install IR C2100 system software where in get it
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Here is the Canon support website. If you can find you model , you can download a manual which contain all the information that you need.I coundn't find it because I dont know enough about you printer. Ink? etc.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
