Question about Kirby G6 Bagged Upright Vacuum
My kirby sentria shuts down while I am vacuuming
  • 357 Answers
RockyNR1
  • 324 Answers
SOURCE: kirby Sentria shampooer
HERE is the shampooer manual. There is no suction involved picking up the water. It simply scrubs the solution off the rug and throws it in the tray in front of the Kirby vacuum.
Posted on Nov 25, 2008
SOURCE: Kirby Sentria
If the green light is off, then its time to replace the band. This video shows you how.
Posted on Dec 30, 2008
  • 7 Answers
SOURCE: kirby sentria carpet shampooer
you dont **** out the water....if you use the reccomended Kirby shampoo there is no need to **** out the water because it is a semi dry liquid ...it will dry by its self in about 1 hour....I,ve been with Kirby for 16 years now ...i will know
Posted on May 19, 2009
b0sslady2001
  • 357 Answers
SOURCE: How do I connect upholstery cleaner to Kirby Sentria
Here is a link to available owners manuals...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQ_fsubZ7656839QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Hope this helps,
Marci
Posted on Jun 28, 2009
SOURCE: Kirby Sentria vacuum -- can't figure out how to hook up main hose to vacuum floors
First you need to press the foot pedal for the height adjustment all the way down to lift the front of the vacuum off the floor. On the front top of the vacuum where the LED lights are is a cover. That section will lift up by lifting just below the LED's. Once it's lifted up there are some visual instructions, but here's what they are saying. The little circle on the front divided with the word KIRBY is the belt release. The section of the circle with the word on it will pull out. Like a wind-up flashlight it will turn from lining up with the green arrow counter clockwise 360 degrees and lining up with the red arrow. This takes a little pressure to turn it. Now just above this circle, under the LED bonnet, there is a lever that holds this whole front end on. It must be turned also counter clockwise to remove and front then slips off. The reverse would be used to put the beater roller portion back on. Also this would be the way to slip on the hose attachment to **** through it instead. I hope this is a little clearer.
Posted on Feb 06, 2010
Where is reset button on my Kirbyville Sentria
Kirby Sentrias don't have a reset button. If it suddenly shut off it could be a number of different problems. It could be one of three safety switches or the thermal cutoff in the motor has tripped and may reset after a cooling period.
Jul 16, 2016 | Vacuums
How do I replace a kirby g7 drive pedal?
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 04, 2014 | Kirby G6 Bagged Upright Vacuum
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
How to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
Mar 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria shampooer
Jul 19, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
125 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
