Question about Hotpoint Washing Machines
WMFG8537 F05 error code
5 Suggested Answers
  • 3230 Answers
SOURCE: Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Posted on Mar 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: What is the F05 error code for on my Kenmore elite he 4t washer
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: What does the error code F05 mean on the HE 4t
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 29, 2010
rickead1
  • 1998 Answers
SOURCE: error code f05 hotpoint ultima
In your service manual it states F05 - Pressure switch jammed on full many times I find this is due to a blockage in the drain line and if you take and clean out the drain line it usually alleviates the problem most of the time due to this error. I also find that while doing this it is best to also check the drain line that comes off the water opump as well as the one that goes from the bottom of the tub to the pump as well. Also checking the pumps impellar that it does spin freely assures future useage without problems for a much longer time with your washer. If you have any further questions message them back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Posted on Nov 14, 2011
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
I have a Kenmore Elite front loading machine machine HE3 that keeps giving me an error code of F05. What does this mean? Obviously I've lost the manual
"F05" is a heat sensor error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Actually, none of the error codes are included with your owner's manual. They are, however, included in the technical data sheet which should be located behind the lower kick panel directly below the door.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
F05 error for Whirlpool GHW9100L Front Load Washer
The following link explains the "F05" error code:
I hope you find this information helpful. I have seen this error code generated by something as simple as a loose connector on the NTC sensor. Hopefully, you can resolve this with no expense. If you do require any parts, however, you can locate parts with illustrations at searspartsdirect.com or repairclinic.com. If you require further assistance, please let me know.
Sep 10, 2008 | Whirlpool GHW9100L Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
