Question about Symbol LS9208 Hands Free Barcode Scanner
Symbol model ls9208 keeps beeping
It doesnt start. it keeps beeping with quick beeps but doesnt start
5 Suggested Answers
SOURCE: ls 2208 can i program enter +f12+ y(es)+enter
manual www.symbol.com
Posted on Jun 09, 2008
SOURCE: I need to turn off the beep on the Symbol MC9090 w...
Create a registry setting, putting volume to 0 will (almost) get of the sound ....
[HKEY_CURRENT_USER\Software\Symbol\SymbolPB]
"DecodeVolume"=2
"DecodeFrequency"=00FF
"InvalidDecodeFrequency"=0FFF
"DecodeDuration"=850
Posted on Jun 22, 2010
SOURCE: my ls9208-sr 10001n scanner will not scan. The
sell lit DARE KURK !! YO UM SAYEN RYTE !!
Posted on Sep 22, 2010
SOURCE: LS9208 SR10001NSWW It was working last
Ok, what may have happened is that the USB layer may have become corrupted and all that is needed is a refreshing of the USB layer and drivers. here is what to do.
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Now remove, (Add/Remove software) ALL software to do with your Scanner, everything. Restart the computer, and then reinstall the USB drivers and software for the Scanner, DO NOT plug the unit into the USB port yet. After the drivers and software are installed, reboot, then and only then (Or unless you are requested to during the scanner install) plug in the USB scanner. After this is all installed, install any "Other" USB drivers and Software, and then plug in any "Other" removable USB devices, Then Reboot, leaving everything now used plugged in, and then test to make sure that the issue is resolved.
If you don't have success then you will have to try them on another PC, to see if they actually work?
You didn't say what Operating System you are trying to install on? If Vista, Win7 etc, try installing as Administrator, and set compatibility mode for XP SP2....then install...
Posted on Nov 15, 2010
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
I require factory reset barcode for symbol ls9208
The barcode is located in the manual at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6083307apdf&sliceId=&dialogID=27078141&stateId=0%200%2027076163 at the page 45 , the name is "Set Factory Defaults"
May 13, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Unit has been installed for 2 weeks with a new battery when installed. Came home today, it was beeping. I pushed the middle button but it still keeps beeping.
new batteries are probably dying-- new doesnt mean they cant be faulty install new batteries and observe if problem returns quickly
Feb 04, 2010 | Kidde Nighthawk Combo Gas/co Detector
I have Symbol LS9208 barcode scanner, but I don't have any cables. I need schematics of USB or RS232 cable for this scanner.
You'll never be able to make the appropriate cables - and Motorola (they bought Symbol) no longer publishes schematics for cables. Contact the Motorola helpdesk at 1-800-653-5350
Oct 28, 2009 | Symbol LS9208 Hands Free Barcode Scanner
LS2208 beeps to ignolage the scan but puts no information
I don't know if this applies to the LS22208.
Symbol Support FAQ says;
A slow continuous flashing LED on the LS9208 indicates that the LS9208 has been put into “programming mode” and is ready to scan programming bar codes. Once the LS9208 is correctly programmed, the LED should stop flashing and remain on, indicating that the scanner is ready for use.
A fast, continuously flashing LED on the LS9208 indicates an internal problem. When the LED is in this state, the LS9208 laser is also shut off for regulatory reasons.
We support these for some big retailers. When they call with that issue 99/100 it's reseat the cable from the base of the scanner (or the system if accesible), no re-programming).
Jan 15, 2009 | Symbol LS2208 Handheld
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
May 23, 2007 | Sony Handycam CCD-TRV68 Camcorder
Symbol LS9208 Hands Free Barcode Scanner Logo
135 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
