Question about Whirlpool AWM5125/1 Front Load Washer
Awm 5125 front load womt spin
My smachine wont spin sound like its trying but then stops is there any way to test the motor or anyone with another solution
  • martyrfc Jan 20, 2009
    i removed the belt and the motor turns when not connected to belt but as soon as the belt is applied the motor wont turn
    President:
  • 2,559 Answers
Check the agitator(the big plastic piece in the center)you can remove the cap in the top and there will be a bolt that holds it on,remove the bolt and see if the plastic gears are worn out.
Please rate this solution
Posted on Jan 20, 2009
    Genius:
  • 2,920 Answers
If there is something stuck in the pump it wont allow it to spin or drain.
When my washer is spinning , it has a clunking sound even when it is empty. Do you know what it could be?
Whirlpool has been having problems with their tub bearings. Not an easy fix at all. But to me it sounds like you
may have a broken shock. Pull the bottom panel off (three screws on the bottom) and you'll see the shocks.
It will be obvious to the eye. If that is the problem you can replace just that one, but I would go ahead and
replace all four...hope this helps.
Apr 02, 2011 | Whirlpool AWM029 Front Load Washer
My awm wont go on spin cycle
check water is pumping out. If so then it sounds like your motor brushes may need replacing, on main motor
Feb 19, 2010 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
My whirlpool awm 5125 wont fill up at start of washing
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
Sep 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
WHIRLPOOL 5125 LOUND NOISE
I take it you are refering to the AWM5125
The sound you hear are the bearings on their way out. You will need a replacement rear tub half
Jan 26, 2009 | Whirlpool AWM5125/1 Front Load Washer
Awm 5125 front load
I had the same problem tonight!! I opened the filter at the front and found one of my baby sons socks and 81 cents!
The machine is draining away perfectly now, but the floor got soaked when I opened it, so be prepared.
Hope this helps...
Jan 17, 2009 | Whirlpool AWM5125/1 Front Load Washer
I am trying to locate the brushes in my whirlpool awm 5125 washer i have taken the top off but cant locate them
the brushes are on the motor which is located at the rear of the machine sitting just under the wash unit.
You will need a 10mm spanner to remove the bolts holding the motor on. unclip the wiring to the motor and remove.
the carbon brushes are located on the rear of the motor - one on each side of the commutator,
you will need a philips screw driver to remove the brushes
Jan 15, 2009 | Whirlpool AWM5125/1 Front Load Washer
Won't spin fast.
sounds like motor control ..but three thing can keep it from not spinning .. Motor control- main control and or door lock... if just the spin cycle it may be the motor control..let me know what you find..
Aug 29, 2007 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
190 people viewed this question
Dan Webster
Dan Webster
Sal De
