Question about Makita Drills
My hr2455 hammer drill is leaking oil out of the front coller
N/a
2 Suggested Answers
  • 313 Answers
SOURCE: throwing oil
i really dont worry about the leak near the shaft because with out the oil in the shaft there is a possibility that the shaft can jam. even dewalt new hammer when you purchase it come with the grease/lube like a toothpaste size. this is to lube the bits for the purpose the bit/shaft can move freely & also can hammer freely. our you can do is to dis-assemble the front end sleeve & remove the excess oil.will i agree weather can also change the viscosity of the oil. varsol cleaner can do the trick available at walmart.
Posted on Jun 07, 2008
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
The drill is leaking oil
As my knowledge drills not use oil just grease in the bearings.But if you need to service and the drill is not too old and the repair is not cost too much you can find parts at Hilti Online or by your self using the Hilti Manuals.
Nov 11, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Brand new Hiyachi DH24PC3 leaking oil from chuck on first use while using hammer only chisel application - is this due to overheating ?
Hi, these impact drills need greese to function properly and some modles leek more than others. As its new you could ask for a new seal, as this is what is allowing the oil to leek. Hope this helps
Jul 05, 2010 | Hitachi 3/4", Variable Speed Reservible,...
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a Milwaukee 1 1/8'' heavy duty hammer drill, and it is fairly new, and I can't get any bits to lock in place. The coller that the bit fits through doesn't slide back and forth. What can I do to get...
Milwaukee has a 5 yr warranty on all their tools. Best thing to do is find a service center in your area and have them look at it. Sounds like the bit collar is stuck or possibly cracked. No sense in spending money on the tool if you can get it covered under warranty.
Jan 25, 2010 | Drills
Oil leaking from gear box on hammer drill
Where is the oil leaking from. By the chuck, or the selector knob, or is it leaking from where the gear housing meets the motor housing. I could be one of 3 things. There is a seal between the two housings that could be damaged, not likely though. There is an oring on the selector knob that can get worn, and there is a sealed bearing on the spindle that should not let any oil through. There should not be any oil in this tool for lubrication. Grease is used in this tool for lubrication. If you are getting oil or a liquidy type substance coming out it is more than likely the grease has broken down and needs to be replaced.
Oct 14, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Looking to add oil to rotary hammer Bosch / Bulldog
the oil seal is broken, remove front cover at the chuck end of the drill, and replace the seal,
Jul 21, 2009 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Throwing oil
Oct 15, 2007 | Bosch HCBG500, 5 Pc Industrial Hammer...
Drills Logo
50 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
