How to clean heat exchanger on ferroli f24b - Heating & Cooling
2 Suggested Answers
SOURCE: Ferroli DOM F24B Is leaking
Yes, this is a common problem on the domi compact. unfortunately ferroli accept no responsibility if not in warranty period! can be a costly repair..
Posted on Aug 19, 2008
Ferroli he31c fault code a26 heating comes on for 10 min then goes off
After having the same fault and emailing ferroli support - A26 means the system pressure is too high. Sure enough mine was reading 2 bars, I vented down to 1 and am now back in business.
Mar 24, 2013 | Quasar HQ2051TH Air Conditioner
How do i reseat the prv on a ferroli f24b boiler?
Hi, any pressure relief valves i have ever worked on, can't be reset. They are there to release water pressure that builds to high. If they continue to leak if you have discharged it, you can tap on it to see if you can get it to seal, or just replace it if it continues to run or drip water.
Sincerely,
Shastalaker7
Dec 30, 2010 | Heating & Cooling
Dirty injectors on a Saturday morning in an isolated village
WHEN YOU NEED CLEAN I NEJECTER YOU MAY BE CLEANA ONCE DRUM IN WATER+ HCL CIRCULET 15MIN
AFTER CIRCULATE CLEAN WATER
ALSO CIRCULAT WATER+ EDTA+ SMBS POWDER
YOUR INJECTER WILL 80 % PER CLEAN
Mar 06, 2010 | Water Heaters
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Leaking from secondary heat exchanger
Hi cgcol
I just had the same problem with the same boiler and was recommended to get in touch with a company called Wolseley uk. http://www.wolseley.co.uk/servlet/reality/rscp/IN.BRADETFRMBP1?app=centers&ses=99999|47543&website=www.wolseley.co.uk
link is to their website branch locator. You need to click on parts center on the left hand side of your screen under branch locator, then put your post code in as easy as 123. The parts you need are o rings. They come as a set, their part number for the set is 459382 FROLI 39817620 ORING SET as shown on my invoice. Only cost £7.19 + VAT. Plus bought 798007 REGIN REGZ40 SILICONE GREASE 50G cost £5.47 + VAT (smallest size they do). This is to lube Orings before fitting and pushing pipes together. Make sure you have turned all stop taps off that are under the boiler and drained rads.
Hope this has been a help!
Jul 13, 2009 | Fujitsu Heating & Cooling
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Ferroli DOM F24B Is leaking from the two 22mm pipes on the secondary heat exchanger
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
