Question about Jura Capresso C1500 Espresso & Coffee Maker
Capresso c1500 leaking water on right side - Jura Capresso C1500 Espresso & Coffee Maker
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: My Jura Capresso, Z5 is
Hi
The connectors on capresso machines are very tricky. The reason for the leaking could be to do with the seals. Take it apart and make sure all the rings and pressing clamps are in the right place. Also take a good look and on your hot water tank, and the pressure relief valve in back of machine.
Also it is recommended that the Jura coffee machines to be serviced every 2 years.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 10, 2011
Need to dissassemble Jura Capresso C1500
I just opened up my Jura Capresso C1500 Machine. It's a little tricky, but here is how I did it. I gently pryed the front part of the top off. There is a tab connector in the very front of the oval in front center. Lift (or gently pry with a flat head screwdriver) straight up until it comes free. There are several other tabs that will lift straight up on both sides of the top. However, there are two tabs in the back (one on either side where you see the black pins protruding out the back top of the machine) that are encircled around the pins. The only way I could get those off was by gently prying until the tabs snapped off cleanly. I pryed the one on the right first, and it stayed intact except for breaking off the bottom of the circle; so it will actually still snap into place back over the pin. To free the left tab I simply lifted the lid up and down several times until it snapped off cleanly. There are so many other tabs that fit tightly into rectangle-shaped sockets that breaking the back two did not change my machine's appearance or function. Once the top was off, you can access a lot of its workings including the grinder, top water tube, spout, etc. I use dark beans that are slightly oily so I took off the bean compartment, silicone funnel ring, and attachments and cleaned them thoroughly with hot, soapy water. We found a pebble or two in our beans through the 8 years we have used it and I think they have done some damage on the grinder.
Dec 25, 2012 | Jura Capresso Coffee Makers & Espresso...
Any idea what brand of tubing connectors Jura Capresso uses on their machines and where I can get repalcements? The right angle connector going into the boiler is leaking along the seam.
Legris,
but shorten the tube 5 mm, if the leak is at the tube side.
Mostly it helps.
otherwise change the thermoblock, there are new connectors in.
Nov 23, 2011 | Jura Capresso Impressa S9 Coffee...
My C1500 has started leaking water out the bottom. I think it is coming from the right-hand side, but not sure. It doesn't seem to be coming from the tank and it is coffee-colored water. Any...
I'm working on the same problem, I need someone who reads technical swiss-german to help. There is a pump on the bottom right that drives cold water into the boiler. The connector on the bottom of the boiler (brass to vinyl plastic) came apart on mine. On a german language expresso maker website there are several parts that address this problem, the difficulty I'm having is figuring out which part fits tthe boiler I have as apparently this is a problem on serveral version and there have been re-designed connectors (mine doesn't look exactly like the one in the picture
http://www.kaffeemaschinendoctor.de/ReparatursetsWerkzeug/Dicht-/Reparatursets/Jura-Reparatur-Dichtset-fuer-die-Heizpatrone::101.html
Jul 18, 2011 | Jura Capresso C1500 Espresso & Coffee...
I bought a used Jura Capresso CoffeeTec 471. When i fill the water container and place the water container in the unit, it leaks water all over my counter. It seems the gaskets just can't hold the flow...
I had the same problem. I filled the water container and held it up for a while to make sure the two plunger/valves were not leaking. They held water well so I knoew it was probably not the tank. I called Capresso at 800-767-3554 and spoke to a tech. She asked me to test the water container and I told her I had already done this. She said then unless it was an internal problem it probably was the two seating valves that the tank fits into. She said the soft rubber gets hard over time. She sent them to me for free. I tried them today and when I took out the old ones they were very hard and the plastic cover was a little nicked. The new rubber is very plyable and when I put them in and seated the full water tank it made a nice rubber-to-plastic squeeking sound that let me know it seated correctly. It has been 2 hours so far with ten cups of water and no leaks. If you try this make sure you place the rubber grommet into the hole with the solid side up. It is shapped like an "n" and the open side goes down. Good luck.
Feb 18, 2011 | Jura Capresso CoffeeTEC 471 Coffee Maker
Leaking from the right side.. I have taken apart, and determined one of the pumps has a lot of corrosion... Where can I get a pump???
Take your water supply tank out , fill it and leave it on the counter. My tank had a slow leak that took me forever to find and only leaked when more than 3/4 full. If that doesn't work call the help line 1 -800-220-5701 for parts and service support
Jan 11, 2011 | Jura Capresso Impressa F9 Espresso Machine
It leaks clear water underneath on right side
Hi, wondering if you found the solution, my S9 is doing the same thing. Thanks
Feb 04, 2010 | Jura Capresso C1500 Espresso & Coffee...
Capresso C1500
I have tis same trouble now no water at all I need help fast
Steve
Oct 02, 2009 | Jura Capresso C1500 Espresso & Coffee...
E8 leak
If leaking water from right front when brewing, cleaning or steam then the possible problem is the feed tube from the pressure pump this is mounted with a small o-ring and either the pipe is fractured or the o-ring has perished.
Feb 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso C1500 Espresso & Coffee Maker Logo
54 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
