Question about Kenmore Microwave Ovens
Microwave #721.80529500 how do you remove top grill cover?
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Posted on Feb 08, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: jvm2070sh001 microwave problems: the top grill was
The top grill problem is probably due to the grille's being broken.
There are switches associated with the grille door and if they or their actuators are damaged, it can make the grille motor want to come on (or not come on) when it should (or should not).
This exploded view diagram shows where they are.
The turning off after cooking for 2-3 seconds is a bad magnetron. See this FixYa solution even though your model number is different.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 05, 2010
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Tip
Light bulb out inside over the range microwave oven?
To replace the bulb you will need to first remove the top grille.
- Unplug the power cord, it is usually in the cabinet above the microwave.
- Remove the upper grill, if you stand on a stool and look at the top you will see 4 screws going down into the grill, take those out and carefully pull the top of the grille forward then up and off, it is easier if you do this with the door open.
- In the very front center of the opening you will see a small black cover (about the size of a playing card), remove the cover and you will see the bulb.
- Match it up at your favorite retailer and enjoy watching your food cook again!
on May 02, 2010 | Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Bulb replacement
Is it an over-the-range (OTR) microwave or a countertop microwave? If it's an OTR microwave, are you talking about the light(s) on the bottom of the microwave, or the one that lights up the cavity when you open the door or run the microwave?
If it's an OTR microwave, and the cavity light is burned out, you MAY be able to access it by removing the grill vent by removing the 2 to 4 screws above it. Then, depending on the model, either slide the grill vent to the left and pull it out, or else pull out the top part of it first. Then, if there is one, you may see an access cover behind the grill vent. Unplug the microwave, then remove the 2 screw that holds the access cover in place, and lift up and remove the cover. You should now be able to get to the light bulb.
If it's a counter-top microwave, you will have to remove the complete cover by removing the screws on the back, and possibly a couple of the sides. Note, 2 screws are special security screws to prevent the casual customer from fixing his own microwave oven! UNPLUG THE MICROWAVE FIRST, then remove the cover screws. Slide the cover back about 1/2 inch, and then it should come completely off. You should now be able to see the light bulb to change it. Then reverse the process to put the cover back on. I hope this helps.
Oct 21, 2014 | Microwave Ovens
How do I change light bulb
Lamp replacement requires removal of the outer cover to gain access. There can be dangerous voltage exposed inside even with power disconnected so extra caution is advised.
Sep 23, 2014 | Microwave Ovens
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
May 06, 2010 | Maytag Over-the-Range Microwave
Lightbulb is burned out
May 02, 2010 | Whirlpool MH7140XF Microwave Oven
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
