Question about SanDisk Sansa e250 MP3 Player
I Can't Remove Songs (different from the others)
I tried using Windows Media Player to remove songs but as soon as i click on MUSIC...it freezes. So I tried to use My Computer to remove and the same thing happens when i click on MUSIC.. any help??
    Scholar:
  • 155 Answers
Can you access the menus of the player? Change the settings to MSC and format the player in the my computer. This is the fastest way to delete all files in the player. And would ensure that there are no bad files in the player.
Posted on Jul 24, 2007
SOURCE:
Deleting songs from a Coby MPC855 player
When using Windows Media Player 11 as this is common for the MPC885, you can delete songs running this software and making connection from the player to the computer using the provided USB cable.
In the Library menu of WMP11, the Coby player should show up on the left side in the list.
When clicking Music in the left corner of the second bar on top of WMP11, all music shows up from preselected synchronization maps on the computer plus the player.
Click on the player to see the content and delete the songs you'd like to remove.
Only setup guide available for this player:
http://www.cobyusa.com/files/setupguide/MPC885_SG.pdf
Need more help ? Just post a comment.
Dec 30, 2009 | Coby MPC885 MP3 Player
How do I downloald songs on my new MP3
If you are downloading songs onto your player from Cd's that you have, you will first need to copy the music from your Cd's into a folder. Put all of your songs into your My Music folder. With some players, you can simply navigate to where your music is, right click on the file, select Copy, then navigate to where your player is and select paste.
Your player should be hooked up to your computer via your usb cord, which should have come with your player. If you are not sure where your mp3 player is on your computer, try going into My Computer. You should see something like Local Disk (C:), Removable Disk (F:) or Removable Disk (J:). My players usually show up in Removable Disk (J:). If you are lucky you will see the mp3 player file as soon as you go into My Computer. But if not, click on different removable files until you find yours.
Once you have found your player, click to go into it. You should see a list of folders. There should be one that says, Music. Go into that. Past the music file that you previously copied by right-clicking and selecting Paste. Your music file will transfer.
You can also transfer your music files via Windows Media Player. To do this, start up the Windows Media Player. At the top of the player you should see Now Playing, Library, Rip, Burn and Sync. Click Sync. If you have music already on your computer (everyone does) you will see the songs already on your computer. Select your song and then drag it over to where it says Sync List. Make sure your device is already connected to your computer! You should see your player in the Sync List. Then click the button that says Start Sync. Thats it!
Dec 28, 2009 | Coby MPC-848 MP3 Player
I cant get my coby mp 815 to pull up its music manager on my new computer, I pluged it in, but it just plays whats already loaded on it? whats the music manager?
If I was you I would use either Windows Media Player or Drag and Drop your files to your player. If you choose to use Windows Media Player you will have the same functions that you will have with the coby music manager. Here is the following ways to add music and files to your player if you choose the above ways to add music:
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 31, 2009 | Audio Players & Recorders
IM TRYING TO DELETE MUSIC FROM MY MP3 PLAYER
Windows Media Player is the program you will be using to delete files off your Sansa. To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
if (!window.netshel_ord) { netshel_ord=Math.random()*1E16;} if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e260 shows full memory in its screen
Connect Sansa to computer
Double-click "My Computer" icon
Double-click Sansa icon (shows up as "Removable Drive" on some computers)
Select Tools --> Folder Options --> View --> check "Show Hidden Files and Folders"
Double-click Music folder
You should see your music files - you can delete at will.
Or:
My Directions:
Mar 17, 2009 | SanDisk Sansa e260 MP3 Player
How do i download music onto sony walkman if i dont have windows media player 11
try these methods
and any windows media player should work
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
Jan 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Windows media player not wotking
take all data-backup & get a hard-reset... if you have a virus checking application, check your device for virus/bug ; you can get virus checking applications free from the web for your PDAs... Hard-rest will solve your problems... be sure to take your backup of data & contacts...
Aug 26, 2008 | HTC Touch P3450 Smartphone
Downloading music
most likely it requires windows media player version 10 or higher which unfortunately is not compatible with windows 98 so that way will not work. You may be able to bypass windows media player by going to the manufactuers website and downloading a specialized driver for windows 98 and then drag and dropping your music onto the pkayer if this doesn't work I am sorry
Aug 04, 2008 | Nextar MA933A MP3 Player
Disney mix max problem
Connect your player to the USB port on your computer using the USB connector on the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is the player's internal memory. To add more files and songs to your player simply drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX' window.
For Windows XP, you can utilize Windows Media Player 10 software to convert music on an audio CD into MP3 or WMA format as follows:
Open the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top tool bar. Insert a Music CD into the CD-ROM drive of your computer.
Click on the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option setting menu will appear. Click on Rip Music and set the Rip music to the desired location on the newly ripped music (MP3 format or Windows Media Audio format). Adjust the audio quality as desired. When finished, click 'OK' to confirm the settings.
Click on the 'Rip Music' icon to start ripping the music to your computer.
When the music tracks are ripped; connect the player to your computer. Open the 'MIX-MAX' window and open the ripped music location window.
To add the transferred/ripped music file/songs to your player simply drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window.
When the files are finished loading into the player, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to convert music on an audio CD into MP3 or WMA format.
Downloading WMA files with DRM using Windows Media Player 10 (for Windows XP)
To download WMA files with DRM, follow the procedure described below using the previously installed Windows Media Player 10. Before beginning the procedure please turn the unit on and connect the unit to the computer as previously described.
Open the 'Windows Media Player Browser 10' and click on 'Sync'.
Click on the 'Sync List' pull-down menu to locate the music files you wish to download. Then make sure to click the box next to the files.
Select the Portable Device that you want to copy to from the right side drop-down menu. Click 'Start Sync' to start downloading the WMA file(s) with DRM to the Portable Device.
After finished downloading all the desired files to your unit, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to download WMA files with DRM to your player.
Jun 16, 2008 | Disney Mix Max Digital Media Player
HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
Apr 12, 2008 | Sony Walkman NWZ-B105F MP3 Player
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
