Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rf323tedbsr/aa water filter leaking
Filter leaks
kram26
  • 544 Answers
SOURCE: samsung fridge filter leaking
HI,
your drain is clogged.you may have a catch for your drain where you see leak coming from.that may pull off and you can see if their is trash build up in it.you are going to need to take the panel off the back of freezer.inside back of freezer you will see screws.they will need to come out,if you have ice maker that will need to be removed also.once back panel is off you will see your coils,beneath the coils it will most likely have a sheet of ice.tturn machine off and take a hair dryer and defrost the ice.once ice is gone take a cup of hot water and run thru drain to see if unclogged.repeat if drain is not clear.the ice in drain tube will eventually unclog.I use a steamer.much quicker.
thanks,
Posted on Mar 22, 2009
  • 10865 Answers
SOURCE: FILTER LEAKS!
go to the hardware store or even a home depot or lowes and get some plumbers pipe dope........a small tube will be plenty. remove the filter and dope up the areas where the two components hook together. it is magical.
Posted on May 20, 2009
  • 97 Answers
SOURCE: RS253BAWW Samsung Side fridge water leak
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Actually a pretty common concern... second time in two hours I've seen it. :D
Posted on Jul 29, 2009
SOURCE: Samsung rs255sl refrigerator leaks water at water
The problem is at the water lines behind the kick plate. Remove the 3 screws on the kick plate. You should see too water lines a red and a blue coupling. Push the water lines in rather forcefully towards each other. When looking at the couplings on your left hand side you should see a small gray lip. You need to slide those outwards and insert the red clips (that should have been left in the plastic bag with the allen key used to adjust the door height) in between the lip and the coupling as they are compression fittings. This should fix your problem right up!
Posted on Oct 24, 2010
  • 354 Answers
SOURCE: water filter on my side
Well first thing shut the water off,drain water out by removing filter ,check the o-ring on filter and if you recently changed the filter you possibly pinched it when reinstalling and now you need a new. If not it could have a flat spot on it and wore out either way you need a new on.Appliance store (get model # or take with to match up) or even at times a hardware store that sells o-rings.
Posted on Mar 27, 2011
Ice maker leaks water and freezes up then stops working
Sounds like Ice Maker is overfilling. Could be water valve not shutting completely off after filling. Or could be problem with Ice Maker itself.
Sep 15, 2017 | Samsung Refrigerators
I need a filter bypass cap for model RF323TEDBSR
That model does not take a bypass plug if you don't have water coming. Thru the filter housing is bad part number (da97_08006g) and needs to be replaced but you could take it apart you could coupler the water lines and bypass the filter housing also called filter case
Mar 24, 2016 | Samsung Refrigerators
Showing code 8E
This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
Ice Maker For Samsung Refrigerator Model RF323TEDBSR
Sep 26, 2015 | Samsung RF323TEDBSR 31.6 cu. ft. French...
Why does water leak after cleaning the filter?
If you have the manual handy, check the debris filter removal and reinstallation procedure. There may be some little thing that can spell the difference between leaks and no leaks.
Aug 11, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
Oil leaking heavy just above oil filter ,passenger side 2002 crv ,not coming from head oil leaking heavy passenger side above oil filter, not coming from head
If it is leaking at the oil filter the previous rubber gasket may have stuck to the block. When the new oil filter was installed then the gasket was doubled and will leak.
Jan 04, 2015 | Honda Cars & Trucks
How do i reset a Samsung DW80F800UWS with display showing "LE"
Oh, that stands for Leaking - Samsungs have a plastic bottom that catches leaked water which activates a leak detector, which puts up the LEakin message. Most often leaks occur around the drain pump or drain hose. To clear the error, you must remove the standing water under the leak detector; no key sequence will remove that error.
Jan 04, 2015 | Samsung DW80F800UWS/AA 24" Stainless Steel...
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Samsung RS2630SH Side by Side Refrigerator Logo
192 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
