Replacement tv stand for Vizio VG 47L 10A, P/N: 3647-0012-0334
4 Suggested Answers
SOURCE: tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Posted on Jul 19, 2010
gopakumarg43
  • 75581 Answers
SOURCE: no sound for DVD and
Hello
The picture in your Vizio HD plasma TV is Ok, and troule is only with sound, I thinks and posts this solution.
Just reset your TV to its factory settings first and observe the change. If it doesn't help, sound detecting section in the printed ciruit board is faulty. It is integrated with sound board, and cannot be repaire, as it contains SMD [Suface Mount Devices] on board, which needs special equipements to resolder it out and solder in. You cnnot do this at home. Sometimes, sound detection section as a whole as printed circuit boad should be replaced. After this card replacement, special software installation should be done, to get it work properly, and this should be done by any experienced techinican, who has most modern testing equipments with him. Anyway, just reset it to factory settings and see. If the fault is doue to any setting defects, this will resolve it. to get it factory settings, do the following.
Enter the setup mode screen.
There are Closed Caption, Language, Factory reset, Image cleaner and firmware version will be displayed.
With the help of UP/Down and Forward/Backward arrow buttons hilight the factory setting option and set it ON and press OK or Enter.
Set will go Off and will come back again with factory settings. After that switch OFF the TV with it front panel power ON'OFF button. Wait for a minute, switch it On again and check. If the fault is due to any settings you have done, this process will rectify it. Ohterwise decide yourself what to do. OK
Posted on Feb 02, 2011
SOURCE: can't remove tv stand from vizio p50 hdtv20A
You have to unscrew the stand from the set, the screws are on the back. I believe there are a total of 8 screws. You will then have to lift the set off of the stand.
Posted on Dec 06, 2012
Vizio vp50hdtv10a
Check all voltages on psu output. check solder job and polarity on caps you replaced.
Aug 02, 2014 | Vizio VP50 10A 50 in. Plasma TV
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Vizio base stand model vx37l
You can get replacement Vizio remotes from Walmart, $10. As far as the pedestal, I can't locate one either. I would suggest checking Ebay frequently. I recycle LCD sets and come across rare pedestals. If you would like, visit our website, click on Contact US and leave your contact info. I will put you down on our Wish List and contact you if we get the pedestal in stock.
www.back2lifeelectronics.com
Jan 10, 2013 | Vizio VX37L Television
Vizio VP50 10A picture has shifted to the right, how do I adjust back to full screen?
You have to get into its service mode option to make it right. For more details, visit the site 'Electro-help". You can search for it by typing this site name to your search engines' search box, and click search.
Jun 14, 2012 | Vizio VP50 10A 50 in. Plasma TV
I have a Vizio 37" TV (VW37L HDTV 10A) bought in
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ ///
Sep 03, 2017 | Vizio VW37L 37 in. LCD TV
Tv Vizio VX37L HDTV 10A
Jul 19, 2010 | Vizio VX37L Television
Set will not turn on
VP322 HDTV 10a is notorious for popping 4 radial capacitors on the power control board . Two of them are 1000uF 25A, and two 3000uF 10A. You can spot them because the tops will be bulged, and leaking electrolite. Make sure you replace them with radial electrolite caps> they coat 'round $10.
Dec 30, 2009 | Vizio VP322 32 in. Plasma TV
I have a Vizio hdtv 32'' lcd the power button is yellow, when I turn the tv on the button turns green but thats all that happens no pic or sound the model is Vizio L32HDTV 10A
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Sep 13, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
