Question about KitchenAid Refrigerators
How to remove deli tray endcap from kitchenaid kfc022evlbl1 left side
Steps to remove and replace the endcap
4 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: FACING THE REFRIGERATOR THE LEFT SIDE OF THE DELI
Hi, I will need a model # so I can look this up and get part name and #.
Vic
Posted on Jul 04, 2009
ercupa190
  • 12223 Answers
SOURCE: What are the steps to installing the motor belt and front left endcap to a Weslo treadmill.
Watch this video:
you must proceed as the video.
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
remember Not to tigh the drive belt motor so much. That will be create another problem: Noise, stopping frequently, smell to hot. etc.
sincerely.
e.cuadra
Posted on Nov 16, 2011
joelcarringt
  • 42 Answers
SOURCE: my Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Posted on Feb 03, 2015
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Feb 03, 2015 | KitchenAid Refrigerators
Took our deli drawer to clean. Can't reassemble. Help
If it's the deli drawer from the bottom of you refer and you took the entire assembly out at once you will know because it all came apart when you started cleaning it. If it's got two drawers then you now have a piece of glass a frame with legs on it and two drawers. So open the refer all the way, look at the back and the sides where you removed it from, you'll see some groves or ridges or little nubs take the frame by its self and fit it into those places you see, then take the drawers one at a time ( usually the one closest to the door hinge is best to start) and slide them back into place. take your time because like a dresser drawer there is a notch that you will have to work with that's designed to keep you from pulling it completely out when you open it. then place the glass into the frame on top and your done.
Oct 02, 2012 | KitchenAid Refrigerators
Deli drawer freezing food
The temperature in the section or the refrigerator isn't set correctly.
Also, check the thermostats if it is functioning correctly. PLEZE LET ME KNOW.
Sep 17, 2012 | KitchenAid Refrigerators
Replacing endcap part #W10121977
Just completed this project. First of all, there are NO screws to remove. Smack in the middle of the endcap slightly below midline there is a rectangle in "portrait orientation" with a tab in it. Reach in and gently pull tab forward while pulling entire assembly upward and it will pop off. Pull the assembly forward and the perpendicular connecting piece will roll forward as well. At a certain point, the end of the pependicular piece (the one attached to the back of the frig) will pop out as it is just wedged into a small vertical notch in the back wall. Take the entire assembly out of the frig and close the door because i promise you that the door is beeping you and the temp has risen to almost 50 degrees. to remove the sliding portion, you need to depress the remaining two tabs from behind to release the sliding portion and gently squeeze the two tabs on the end of the end cap so that you can separate the two pieces. Go slowly as these pieces are flimsy and fragile. You will have to rotate pieces at the back and front of the endcap to get the pieces out that you need to put back on the new endcap. The drawer slide comes out by depressing the remaining tab (just left of the tab that released the assembly to begin with.). Once you have the new "L" shaped assembly, you are ready to put it in. Start with fitting the back piece back into the tab at the rear of the frig. Fit the assembly into the corner, hold the original tab down and it will snap into place easily. Putting the cover back into place is a bit tricky, you will have to stick the hole of one side od the cover first and then gently pull back the tab on the other side to accommodate the other side hole. I was super careful because I didn't want to break the cover tab that made me have to change the end cabin the first place.
Sep 10, 2012 | KitchenAid Refrigerators
Watch this video:
sincerely.
e.cuadra
Nov 12, 2011 | Exercise & Fitness
Water collects under the deli/meat tray of our Samsung RF267 side by side refrigerator and freezes there. Where does the water come from and how to resolve the problem? Help ALSO Our Samsung front...
The water is coming from a leaking water tank behind the deli/meat tray. It only leaks when you use the water dispenser. You will need to disassemble the deli drawer to get to the water tank and replace the water tank. FOR THE WASHER, call Samsung for service. You may have a control board problem.
Jun 18, 2011 | Samsung Kitchen Ranges
Vegetable crispers and deli tray freeze food.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Feb 15, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
29 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
