I forgot my administrative password in my gateway ms2274
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: ggateway ms2274 shutting down wont start up
onehugo, has the inside of the laptop been cleaned out?
The Gateway MS2274, is also known as part of the Gateway NV52 series of Notebook PC's.
Look on the bottom of the laptop, and post the Model Number.
(Examples, NV5207U, NV5211U, NV5212U, and so on)
http://support.gateway.com/us/en/s/notebook/2009/gateway/nv/nv52/NV52nv.shtml
(Clicking on Product Views, then on the different product views given, will show you the ms2274 is part of the NV52 series )
The laptop uses the same cooling system as most laptops.
1) Cooling Tube:
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
At one end of the Cooling Tube there are two small metal plates. One plate sits on top of the Processor. The other plate sits on top of the graphics chipset.
At the other end of the Cooling Tube a Heatsink is mounted.
2) Heatsink:
For this series it is a rectangular finned object. Small strip of metal with Tall, Thin fins protruding from it.
3) Fan Assembly:
Fan set inside a backwards D shaped shroud. (Surrounding cage)
The Fan Assembly draws air up from the bottom, then exhausts the heated air out of the side of the laptop.
Operation:
The two small metal plates absorb heat from the Processor, and graphics chipset.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat along it, up to the Heatsink
The Heatsink absorbs the heat, then radiates it away with the Tall, Thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
This is an up close example of the cooling system used, on the Gateway NV52 series of Notebook PC's,
http://www.laptopneeds.com/parts/show/120817549354/
Scroll the page down to the photos.
The bottom photo shows the cooling system, as it looks removed from the laptop, and the side that contacts the Processor, and graphics chipset.
Here I am able to show you the metal plate surface, that contacts the Processor, and graphics chipset.
With this design there is only one large metal plate to do both jobs, instead of two small separate metal plates.
Coming from the end of the copper Cooling Tube, and going to the Left;
1) You will see a small square, covered partway with a gray Thermal Paste.
(Thermal Paste makes a triangle shape)
This pad sits on top of the Processor/
2) Coming to the left a little further you will see a rectangular copper pad, with gray Thermal Paste smeared on it. This pad sits on top of the graphics chipset.
[ The Processor and graphics chipset, are the two hardware components inside a computer, that give off the most heat ]
Also here you will see at the side of the (Black) Fan Assemblies shroud, is the finned Heatsink.
Point of this long 'dissertation'?
Want you to see the cooling system, and especially the fins of the Heatsink.
Air is drawn up by that fan, and pushed through the fins of the Heatsink.
ANYTHING the fan draws up with the air, is pushed through the fins of the Heatsink
Dust, dirt, hair, food crumbs, lint, ...you name it, is drawn in.
This coats the fan blades, fan's center hub, and surrounding cage. (Shroud)
Also clogs the fins of the Heatsink.
This drops the cooling capacity of the cooling system, tremendously.
The Processor, and graphics chipset overheats.
When a Processor overheats it turns off. (BIOS turns it off)
No Processor operating, no computer.
After a few times of this error codes are logged in. BIOS won't turn the Processor on, until the problem is fixed, and error codes are cleared.
Solution is to clean the inside of the laptop out.
Laptop partially disassembled;
Use an ESD wrist strap, ($3 to $6), and connect it's alligator clip to a good ground source.
Use compressed air for computers, a soft small brush, (Makeup brush?). and Q-tips.
No sir/ma'am.
Using compressed air at the Fan Assemblies opening, at the bottom of the laptop, (Air Intake Duct) WILL NOT DO THE JOB CORRECTLY.
It will just shove the gunk further into the fins of the Heatsink.
Use compressed air at the side of the laptop, and the exhaust port?
Even WORSE!
Also;
You see I mentioned Thermal Paste.
The bottom of the two pads on the large metal plate, on the Cooling Tube, (Whew!), is not perfectly smooth.
Neither is the top of the Processor, and graphics chipset.
A magnified view would show imperfections.
'Pitholes, Valleys, and Hills'.
When the two surfaces are mated together, (Pads on top of Processor, and graphics chipset), they create Air Pockets.
Air is an Insulator. Not a Conductor.
Thermal paste fills these imperfections, and is an excellent Conductor of heat. Transfers the heat well.
After time the Thermal Paste dries up. Caused by age, and the heat of the Processor, and graphics chipset.
Fresh, new Thermal Paste should be used.
The top of the Processor, and graphics chipset, plus the bottom of those two pads on the metal plates, should be cleaned THOROUGHLY!
Then fresh, new thermal paste is PROPERLY applied.
Software problem? Windows is messing up?
NO
You stated the laptop is shutting off, BEFORE the operating system is started.
[ You press the Power On button. This is tun presses against a momentary contact switch. The Power On switch.
The first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, then hands the computer over to the O/S.
The Processor isn't turning on, or isn't staying on ]
I can post links to the NV53 series of Notebook PC's, for a Service Manual, and pictorial guide, for disassembly.
With this info you can crossover easily to your NV52 series.
If you wish to clean out the inside of your laptop yourself.
There is ALSO other needed information I will state along with them.
Post back in a Comment.
Regards,
joecoolvette
(Apologizes for the long solution )
Posted on May 17, 2012
Tip
How to Reset Gateway Password?
How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Gateway password.
Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
Optional 2: Gateway password recovery disk helps remove lost laptop password
It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
A. Insert a CD/DVD/USB Flash Drive into the driver.
B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
D. Click "Next" and follow the Wizard to create password reset disk.
Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
Optional 3: Reset Gateway password by accounts with administrative privileges
Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
D. Right-click locked account and select Reset password.
E. After finished, restart PC and login.
Optional 4: Ophcrack Windows Password Recovery software
Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
B. Insert the CD into the locked computer and restart it.
C. When computer starts, we have to press the correct key to enter the boot menu.
D. After select the drive that the CD is in at start menu, do as the following instructions.
If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
on May 06, 2011 | Computers & Internet
Bought a laptop at auction but don't have password to open up
Have a read.
How to Reset Forgotten Password on Gateway Laptop www.windowspasswordsrecovery.com > Resource > Password
A Gateway password is the password that you must enter to log into the administrator or user account on your Gateway laptop or ... You Forgot Gateway Laptop Password?
  • 4 Workable Ways to Recover Gateway Vista password www.windowspasswordsrecovery.com > ... > Windows Vista Password
    Lost Gateway Laptop password? ... 4 Workable Ways to Recover Gateway Vista password. ... you should login Gateway Desktop and enter User Accounts by clicking ...
  • How to Reset or recover the lost Gateway Laptop Windows ... www.windowsloginrecovery.com/reset-gateway-windows-7-password.html
    Forgot your Gateway laptop password? ... How To Get Gateway Windows 7 password reset or ... Reset Admin or other user account passwords with USB Flash ...
  • Gateway Official Site: Worldwide support.gateway.com/s/Mobile/Gateway/M320/3501937sp34.shtml
    Gateway.com Support. Select a country or region. Americas. Canada (English) Canada (Fran?ais) United States; Mexico; Argentina; Brasil; Colombia; Panama; Peru ...
  • Forgot Administrator Password for Your Gateway Computer ... www.top-password.com/knowledge/reset-gateway-password.html
    Forgot Windows login password for your Gateway computer? ... Forgot Windows 8 Password; Reset Windows 7 Password; Bypass Windows 7 Password; Windows Password ...
  • GATEWAY Bios Password, Unlock Your Laptop in minutes gateway-bios-password.biosremoval.com
    Here is the solution to unlock Gateway Bios Password, Gateway Password, Gateway user ... 2013, Gateway Bios Password, Gateway Password ... M320, M320S, M320X ...
  • How to Reset Gateway Laptop Password Windows 7 - Unlock ... www.youtube.com/watch?v=EUx5AjTCLFw
    • BY LYNDON MOSES
    • 3 MIN
    • 14K VIEWS
    • ADDED 2013-11-25
    Video embedded ยท How to Reset Gateway Laptop ... This may be the fastest way to recover a lost Windows 7 password that ... How to crack windows 7 "user login" password ...
  • Feb 11, 2016 | Gateway M320X Notebook
    Forgot pass word.
    if u forget bios password please reset it .
    if u forget system password try to login from administrator if you already sing in with administrator please change the Os .
    Sep 17, 2013 | Gateway CX Computers & Internet
    I forgot my password
    Lost Windows password:
    • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
    • Login as other user (if other user is available) and manage users. Must be an administrator.
    • Reformat computer.
    • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
    There is a free boot CD called Hirens. This one command prompt only.
    Oct 15, 2012 | Gateway TL-58 Notebook
    I forgot my user password to my gateway laptop
    You can bypass Windows User Password, follow the steps below: Step 1: Download Bypass Windows Password software and install it.
    Step 2: Burn a bootable Windows Password Recovery CD/DVD or Windows Password Recovery USB flash drive with the program.
    Step 3: Reset Windows Administrator Password to blank with the burned CD/DVD or USB, then bypassing windows password and regain access to your locked computer.
    May 02, 2012 | Gateway NV55C26u Notebook
    Forgot my administrator password to my Gateway M360 M460 M680
    I also met this problem ever, and I try some common methods just like safe mode, net user but in vain.Afterwards I found a password recovery tool calls Windows Password Rescuer that it helps me solve my problem.The usage is simple so that PC novice can use it, you can see this article:
    http://www.daossoft.com/documents/quick-start-guide-for-using-windows-password-rescuer.html
    Sep 15, 2011 | Computers & Internet
    Forgot my username password so cannot get onto my pc at all, any help would be much appreciated.
    AnyPasskey Windows Password Recovery would be your first choice! This easy-to-use yet powerful Windows password reset tool could reset any account passwords, including Windows local administrator, Domain Administrator and other user account password, etc. instantly by creating a bootable CD/DVD or USB drive on all Windows OS, such as Windows 7, Vista, XP, 2000 and Server 2003, 2008, etc. Just in minutes, no need to re-install Windows or formatting hard disk, you can get access to your computer again without any data losing or file damaging. Pretty easy procedures even it is your first try. 6_19_2012_2_15_03_am.jpg
    May 17, 2011 | Microsoft Windows Vista Ultimate Edition
    Forgot password on Gateway ML6230. How can I reset password on my own?
    restart in safe mode, log in as the administrator, and reset your password from there. Disabling it first from the administrator tends to work best. Best of Luck!
    Aug 31, 2009 | Gateway ML6230 Notebook
    Computers & Internet Logo
    43 people viewed this question
    David Payne
    David Payne
