Question about Samsung Refrigerators
Fridge freezes everything rs26ddapn
The fridge freezes stuff even if i put it on the lowest temperture
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
Bgillespie
  • 89 Answers
SOURCE: my frdge compartment is freezing
Pehaps the damper door motor is burned out or the damper door is just stuck open causing to much air to flow into fridge side. Damper door is located at the very most top-back-left corner of the "fridge" side.... goodluck...
Posted on Dec 02, 2008
Todd_pdx
  • 22 Answers
SOURCE: Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Posted on Apr 06, 2009
BMT60
  • 126 Answers
SOURCE: Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Posted on Apr 25, 2010
Sea Breeze
  • 4654 Answers
SOURCE: MFD2560HEW Bottom freezer french doors. Top shelf
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Posted on Jun 03, 2010
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Apr 10, 2014 | Haier Refrigerators
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
FRE196AS frigidaire fridge/freezer - fridge freezes everything!
Hello Nicola,
I suggest you contact Frigidaire in the UK, and explain the problem to them. I have included their website for you to do so. You can even call them. I checked with Frigidaire in the US and Customer Service tells me your fridge should not be failing at this point. Contact Customer Service and tell them how disappointed you are in the product; explain the issue; and insist they offer assistance to repair it. Frigidaire Customer Service here does not want to lose any customers, and that includes you. Be nice, but firm with them. I hope this helps you in some way. Let me know if I can further assist. Just trying to to help. :)
http://www.frigidaire.co.uk/contact.asp
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Refrigerators Logo
64 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
