Question about Horizon T84 - Treadmill
My treadmill incline won't go down
It is currently all the way up and won't go down
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: incline raises full and wont go down,t84
1)signal false coming console or display board
2) main motor controller is faulty.
3)Pot attached of the elevation motor ,need adjustment
4) geared slip from elevation motor , carring false signal to console.
Proceed to Test it.
Posted on Dec 12, 2011
Pro-form 415LT. The incline/decline is at its highest incline and won't go back down. I did the troubleshooting correctly and still won't go down. Is there something else I can do?
LUBE the rack and gear very well. Adjust the POT small attached, and try again. However you must see the diagram attached Tight any wires and connector very well and clean .Will be a good idea RUN again the software calibratin after you did the adjustment, clean and lube.God bless youf6d33b22-202a-4b16-8ded-0ff86a59d4cf.jpg50d1e909-5210-4c2b-b9b8-58ceb55bc2ed.jpg
Apr 05, 2013 | Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Incline motor ran away, won't work after replacing
see the diagram attached and test test the input motor voltage, if there are the motor is faulty.see my personal TIPS.
God bless you
Nov 18, 2012 | Proform XP 580 Crosstrainer Treadmill...
Won't incline
please RUN the software calibration for troubleshooting, Go to see the instruction manual or goes under the hood and follow the instruction guide.
see the diagram attached.
Nov 07, 2012 | Proform Exercise & Fitness
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
Incline won't shut off
Please RUN The software calibration for diagnose, troubleshooting and fix it.
download your inst.manual from www.iconservice.com or www.fitness.manualsonline.com and proceed according
God bless you
Jul 18, 2012 | Icon Proform 560 Crosstrainer Treadmill
Incline raises full and wont go down,t84
Proceed to Test it.
Dec 11, 2011 | Horizon T84 - Treadmill
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
Horizon t40 incline is stuck
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related11_27_2011_9_37_21_pm.gif
Watch the block diagram, main controller board ha 90% aprox of functions of the treadmill. sincerely.
Nov 27, 2011 | Exercise & Fitness
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
May 08, 2011 | Proform ZT5 Treadmill
Horizon T84 - Treadmill Logo
16 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
