Question about Dishwashers
My Hotpoint Aquarius FDL570 dishwasher door suddenly won't close properly. With a hard push my husband cal fully close it and it still works. Does this mean that we need a new closing catch mechanism? If so what's the approx cost?
2 Suggested Answers
SOURCE: Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Posted on Nov 09, 2008
Hotpoint fdl570
If you live in and area with hard water, it is entirely possible that mineral buildup is blocking the water fill valve. The easiest way to remedy the problem will b e to replace the valve assembly.
Apr 26, 2014 | Hotpoint Dishwashers
I have a hotpoint aquarius dishwasher. although the door shuts it will not lock. Sometimes the door will almost shut but the lock seems to jam. Thanks Jim
Possible that this is a mechanical fault. So you might have to remove and clean the lock with a de-greasing spray and close the door few times as you oil it. this might solve the issue.
Please find help on the link below for tips to repair
Dishwasher
Dec 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Mar 20, 2010 | Dishwashers
Hotpoint Aquarius will not start.
I'm old fashioned and am not familiar with the "duff door interlock switch" term. However, you are familiar with the fact that there is a switch that is activated when you close the door. That switch or a post that pushes that switch is not doing it's job.
Could be that the switch is not working properly or the post is broken.
Sep 27, 2009 | Washing Machines
Machine dead after changing the brushes
i presume you checked the motor plug,not sure if there is a cable running from the motor down to the door in this model to ensure the motor is stopped before the door can be opened,id check in this area because they can be troublesome,take out the door lock by taking the front lip of the door rubber and make sure it is closing properly,i wouldnt be looking anywhere else for the fault at this stage-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Sep 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius dishwasher
Oversudsing
This can be due to using a laundry or handwash detergent instead of a specific dishwasher detergent instead. It could also be due to excessive amounts of rinse aid in the dispenser or certain food soils that contain a high level of protein such as eggs.
Oct 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
313 people viewed this question
Top Dishwashers Experts
Owen Barnes
