Question about Hydro Quip Inc HEATER ASSEMBLY FOR VERSA (AIR CONTVER) 228730600523 ()
What does the three blinking lights on my hydroquip spa mean
3 Suggested Answers
  • 990 Answers
SOURCE: Hi, my Hydroquip powered spa is running
Check for power at the wire terminals. If you have power then you probably have a bad element and will need to replace it. If not your temp sensor has probably gone bad.
Posted on Nov 28, 2010
Testimonial: "will check power tommorrow, could be temp sensor, I've had them fail before, thanks for you help, Bernie"
  • 111 Answers
SOURCE: Hydroquip heater will not come on & heater indicator light is also out
I would start by checking/replacing the Hi Limit.
When that switch goes bad, it usually shuts down any spa or heater.
Posted on Feb 20, 2012
Great lake spa manuel for 1996 spa
Good Luck! : (
What do you need to know?
Chances are you are needing info on control system?
You may have a "Balboa" control system. Find the Code # and then google. You can get information that way.
I presume you are looking for programming info or topside usage info.
If so, you need to know the manufacturer of the control system and get its required numbers and then search that way.
Spa manufacturers all use only a small handful of control system vendors, unless it is made by them specifically then you have a proprietary system. But your spa probably used Balboa, Gecko or HydroQuip?
Nov 01, 2014 | Pool & Spa
Can I replace my waterway wet end pump model
its not adviseable to go down in Hp (4 to2 )of a pump motor all your jets are not goiing to proform correctly
Aug 26, 2014 | Pool & Spa
My hydroquip 9000 trips the gfci when it starts now. the heater,pump,blower and everything was working fine till the power went out. when the power came on the spa didn't work? there is a reset button on...
If the GFCI is tripping, the reset button will not do anything. If it was fine before the electricity shut off, it is possible that while the pump was not running, water got into the inside of the pack, and that is what is causing the GFCI to trip. An electrical surge may have damaged the GFCI, itself. Those are the two things that might be related to the power going out.
The most common cause for tripping GFCI's are a heater that has a ground fault. A distant second is a bad GFCI. If it starts to run, then quickly trips, it is almost certainly the heater.
Oct 26, 2013 | Pool & Spa
LocF error on hydroquip 9000 e spa
possible bad pump motor or relay to pump or shorted heater element
Oct 21, 2012 | Hydro Quip Inc Pool & Spa
Hydroquip eco-3 series 3 blinking lights
possible bad 2 speed relay
Oct 27, 2017 | Pool & Spa
Nov 27, 2011 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Hi, my Hydroquip powered spa is running continuously but not heating up to the proper temp. All 3 small lights are blinking continuously. I havn't been able to find any trouble shooting info. Thanks for...
Nov 27, 2010 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Hydro Quip Inc HEATER ASSEMBLY FOR VERSA (AIR CONTVER)  228730600523 () Logo
141 people viewed this question
Top Hydro Quip Inc Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Hydro Quip Inc Pool and Spa Expert? Answer questions, earn points and help others
