Question about Whirlpool AWM5125/1 Front Load Washer
Stopping between programs
Checked brushes still plenty carbon smell of burning rubber or plastic when last spun now wont spin
  • 41 Answers
Sounds like your motors on it's way out
Posted on Jun 12, 2010
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
My hm0810b hammers softly and smells like its burning
Stop running it! Don't use tools if they smell like something is burning. Often times you'll make it worse and will make the repair more costly. It could be as simple as replacing the brushes.
To check for worn brushes, remove the black metal cover on the bottom. Then unscrew the black plastic brush caps. Worn brushes will be very low and not have mush carbon left, have a broken spring, or may be sticking in the brush holder and aren't sliding in and out well enough.
If it's something more than that, take it in for repair.
Jan 09, 2012 | Makita HM0810B 11 lb. Demolition Hammer
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Washing machines
sounds like your belt may be loose or the timer control maybe worn out
Aug 17, 2008 | Hotpoint Aquarius WD63 Front Load...
AEG Oko Lavamat 86700
check the carbon brushes on the motor as when they are worn arcing occurs and this could trip the electric and the smell could be the plastic brush holders getting hot due to the arcing
Jul 15, 2008 | Washing Machines
WHDSR209D Washer
if you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Apr 30, 2008 | GE WBSE2090A Top Load Washer
My Ultimate G Kirby started making a strange noise and an unusual smell of burning.
If it is a smell of rubber, then you could have a bad belt and/or brush roll. If it is an electrical smell, then the carbon brushs for the motor may be arc-ing, you will have to check the motor for that.
Apr 20, 2008 | Vacuums
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Whirlpool AWM5125/1 Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
