Programmes in washing mashine Eurotech FL 807 are really long (very old washer?) I want to run an empty mashine on 90 degrees (C) to clean it, can I combine hot water with a shorter programme although the shorter programme usually goes with cooler water?
  • 15,935 Answers
Yes - there is no thermostat to tell it the water is warm - go for it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Eurotech fl 1200
Hallo, I need to understand about function of this mashine in English, please! Thanks a lot!
Best regards, Sveta
Dec 19, 2013 | EuroTech EWC177 Front Load Washer / Dryer
How to fix a smelly Bosch Washer/Dryer?
If door seal has black spots on it, like mould marks,,, change seal and clean out using bicarbonate of soda on a 90 degree wash,,,,, no powder or clothes obviously
Jun 13, 2013 | Washing Machines
What does fL code mean on the wtw6400sw3 washing machine
In your case, when your washer shows LF it means: washer is taking to Long to Fill. And fL would not mean full or overload, because then it would say oL (OverLoad).
I advise you call and ask the company.
U.S.A.:1-800-253-1301.
Canada:1-800-807-6777.
Oct 04, 2012 | Washing Machines
Been dealing with a smelly washer- tried the usual, bleach, vinegar, CLR.....it doesn't seem to have a lint trap.....is there one? where might it be?? Its old but works great other than this.....
Have you tried doing an empty 90 degree wash with white powder?
It does have to be white powder rather than colour powder or any kind of liquid, becauses only white powder has bleaching agents.
Add it helps if you leave the machine empty or clothes, towels etc.
Washing machine smells are usually caused by mildew, and a 90 degree wash with bleaching agents ought to help. If you do this about once a month it should keep the machine clear of mildew.
Jul 25, 2011 | Washing Machines
Washer is not cleaning clothes and the grey rubber seal in turning black
The "black" is normal domestic mildew. When you finish with the washing machine, leave the door ajar for a time (an hour is usually enough) so that the machine atmosphere can clear. This simple step should stop the problem getting worse.
Gently, GENTLY cleaning the rubber with a mild bleach solution will gradually help to cut back the black. (There are also loads of off the shelf anti-mildew sprays from any major supermarket or hardware store.) Just go easy with them and remember to wash rugged old socks or whatever in the washer directly after blitzing it - nothing worse than your best shirt coming out bleached!
Can not really say why your machine is not cleaning clothes from your summary - sorry :)
Good luck
Mar 10, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer has ordor
run a cycle with a heathy amount of bleach on hot. Odor is usually due to bacteria or somehting left behind. Is there any filter that can be cleaned??
Jer
Jan 16, 2010 | Kenmore HE2 Plus Front Load Washer
Washer smelly musty and moldy. How can I get the smell to go away? Is there something we can take apart or clean to stop this smell. Not what you want to smell when you are trying to get fresh clean...
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Jan 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My front load washer is making the laundry room smell with a really bad oder, why & what can I do to fix it?
Non HE detergent will cause your front load washer to have odors. If you do use HE detergent and still have the problem,use the "AFFRESH" product in the washer to neutralize the odor.
Oct 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Eurotech front loading washer, noisy on spin cycle with load.
Hi, could be one of at least two things - if the inner drum can be moved up and down by hand more than an inch when you grab it through the open door it could be the drum bearings that have failed - not good. Usually accompanied by a grinding noise and dirty specks on the clothes.
If the outer drum is really loose in the casing - check with machine unplugged and top removed - then one or more of the very strong springs at the top or the telescopic dampers at the bottom might have come off or broken from it's mounting.
Hope this helps!
If it doesn't, please hold off the rating button and add a comment with more details so I can try to help you further. Cheers, D
Mar 26, 2008 | EuroTech EWF172 Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
